High Lifter Rear Lift Kit for Yamaha Grizzly 660 (02-07; See Notes)
SKU: YLK660-REAR
Price: $66.95
Note: This is a lift kit for the rear only. If you purchased the original Grizzly 660 lift kit that only lifted the front and would like to lift the rear, then you will need to order this product. This lift will only work with rear Gorilla CV axles. This lift will not work with rear stock axles.
Yamaha 2” Lift Kit
2” Lift Kit Features:
·         Zinc plated
·         Rear lift
Yamaha Grizzly 660 (02-07; rear only)
