HIGH CAPACITY SPRING TOOL- USED TO INSTALL HIGH LIFTER SPRINGS ONTO MOST ATV SHOCKS (SEE NOTES)
Price:$49.95
Options:
Universal High Capacity Spring Tool used to install High Lifter Springs on most ATV Shocks.
If you've ever tried to change Lift Springs by hand, you know it can be tricky. The Spring Compression Tool can be a BIG HELP! The Spring Compression Tool compresses the spring down to a size to make it easier to complete installation on the OEM shock. Easy to assemble and breaks down for storage. The Spring Compression Tool is essential for spring jobs.
HIGH CAPACITY SPRING TOOL- USED TO INSTALL HIGH LIFTER SPRINGS ONTO MOST ATV SHOCKS (SEE NOTES) Reviews
Customer Reviews
(2.80)
# of Ratings: 5
1. on 12/17/2016, said:
It was great help in compressing the springs. I couldn't of done it with out the tool.
2. on 10/11/2016, said:
This tool is a complete waste of time and money. Had to take springs to dealer shop.
3. on 9/7/2016, said:
Poor design really didn't even need !
4. on 8/18/2016, said:
This tool is well built and should make installation very straightforward.
5. on 3/28/2011, said:
Drill holes on each end of spring compressor tool (base & handle) to install eye bolts. Use the eye bolts to secure a ratchet strap or hand winch to do the work of comprssing the spring. This takes all stress of the spring force and applies it to the compression tool and not the vise or work bench.
(8 people found this comment helpful, 1 did not)
Showing comments 1-5 of 5
High Lifter Warranties
HIGH CAPACITY SPRING TOOL- USED TO INSTALL HIGH LIFTER SPRINGS ONTO MOST ATV SHOCKS (SEE NOTES) fits the following vehicle(s):
  • 2010 Arctic Cat 1000 TRV
  • 2009 Arctic Cat 1000 TRV Cruiser
  • 2010 Arctic Cat 1000 TRV Cruiser
  • 2003 Arctic Cat 400 Auto 2x4 WD IRS
  • 2004 Arctic Cat 400 Auto 2x4 WD IRS
  • 2003 Arctic Cat 400 Auto 4x4 WD IRS
  • 2004 Arctic Cat 400 Auto 4x4 WD IRS
  • 2005 Arctic Cat 400 Auto 4x4 WD IRS
  • 2006 Arctic Cat 400 Auto 4x4 WD IRS
  • 2007 Arctic Cat 400 Auto 4x4 WD IRS
  • 2008 Arctic Cat 400 Auto 4x4 WD IRS
  • 2005 Arctic Cat 400 Auto 4x4 WD IRS LE
  • 2006 Arctic Cat 400 Auto 4x4 WD IRS LE
  • 2007 Arctic Cat 400 Auto 4x4 WD IRS LE
  • 2002 Arctic Cat 400 MAN 2x4 WD IRS
  • 2003 Arctic Cat 400 MAN 2x4 WD IRS
  • 2004 Arctic Cat 400 MAN 2x4 WD IRS
  • 2002 Arctic Cat 400 MAN 4x4 WD IRS
  • 2004 Arctic Cat 400 MAN 4x4 WD IRS
  • 2005 Arctic Cat 400 MAN 4x4 WD IRS
  • 2006 Arctic Cat 400 MAN 4x4 WD IRS
  • 2007 Arctic Cat 400 MAN 4x4 WD IRS
  • 2010 Arctic Cat 450 Auto 4x4 WD IRS
  • 2011 Arctic Cat 450 Auto 4x4 WD IRS
  • 2011 Arctic Cat 450 Auto 4x4 WD IRS LTD
  • 2002 Arctic Cat 500 Auto 4x4 WD IRS
  • 2003 Arctic Cat 500 Auto 4x4 WD IRS
  • 2004 Arctic Cat 500 Auto 4x4 WD IRS
  • 2005 Arctic Cat 500 Auto 4x4 WD IRS
  • 2006 Arctic Cat 500 Auto 4x4 WD IRS
  • 2007 Arctic Cat 500 Auto 4x4 WD IRS
  • 2008 Arctic Cat 500 Auto 4x4 WD IRS
  • 2009 Arctic Cat 500 Auto 4x4 WD IRS
  • 2002 Arctic Cat 500 MAN 4x4 WD IRS
  • 2003 Arctic Cat 500 MAN 4x4 WD IRS
  • 2004 Arctic Cat 500 MAN 4x4 WD IRS
  • 2005 Arctic Cat 500 MAN 4x4 WD IRS
  • 2006 Arctic Cat 500 MAN 4x4 WD IRS
  • 2007 Arctic Cat 500 MAN 4x4 WD IRS
  • 2008 Arctic Cat 500 MAN 4x4 WD IRS
  • 2009 Arctic Cat 500 MAN 4x4 WD IRS
  • 2003 Arctic Cat 500 TBX Auto 4x4 WD IRS
  • 2004 Arctic Cat 500 TBX Auto 4x4 WD IRS
  • 2005 Arctic Cat 500 TBX Auto 4x4 WD IRS
  • 2006 Arctic Cat 500 TBX Auto 4x4 WD IRS
  • 2003 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2004 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2005 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2006 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2008 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2009 Arctic Cat 500 TRV Auto 4x4 WD IRS
  • 2009 Arctic Cat 550 Auto 2/4 WD IRS H1
  • 2010 Arctic Cat 550 Auto 2/4 WD IRS H1
  • 2009 Arctic Cat 550 Auto 2/4 WD IRS H1 LE
  • 2010 Arctic Cat 550 TRV Auto 2/4 WD IRS H1
  • 2010 Arctic Cat 550 TRV Auto 2/4 WD IRS S GT
  • 2005 Arctic Cat 650 Auto 2/4 WD IRS H1
  • 2007 Arctic Cat 650 Auto 2/4 WD IRS H1
  • 2008 Arctic Cat 650 Auto 2/4 WD IRS H1
  • 2010 Arctic Cat 650 Auto 2/4 WD IRS H1
  • 2007 Arctic Cat 650 Auto 2/4 WD IRS H1 LE
  • 2004 Arctic Cat 650 Auto 2/4 WD IRS LE
  • 2007 Arctic Cat 650 TBX Auto 2/4 WD IRS
  • 2009 Arctic Cat 650 TBX Auto 2/4 WD IRS
  • 2007 Arctic Cat 650 TRV Auto 2/4 WD IRS H1
  • 2008 Arctic Cat 650 TRV Auto 2/4 WD IRS H1
  • 2009 Arctic Cat 650 TRV Auto 2/4 WD IRS H1
  • 2007 Arctic Cat 650 TRV Auto 2/4 WD IRS H1 LE
  • 2005 Arctic Cat 650 V-TWIN Auto 2/4 WD IRS
  • 2006 Arctic Cat 650 V-TWIN Auto 2/4 WD IRS
  • 2005 Arctic Cat 650 V-TWIN Auto 2/4 WD IRS LE
  • 2007 Arctic Cat 700 Auto 2/4 WD IRS
  • 2008 Arctic Cat 700 Auto 2/4 WD IRS
  • 2009 Arctic Cat 700 Auto 2/4 WD IRS H1
  • 2010 Arctic Cat 700 Auto 2/4 WD IRS H1
  • 2009 Arctic Cat 700 Auto 2/4 WD IRS H1 LE
  • 2007 Arctic Cat 700 Auto 2/4 WD IRS LE
  • 2010 Arctic Cat 700 Auto 2/4 WD IRS S
  • 2006 Arctic Cat 700 Auto 2/4 WD IRS SE
  • 2010 Arctic Cat 700 TBX Auto 2/4 WD IRS H1
  • 2008 Arctic Cat 700 TRV Auto 2/4 WD IRS H1 Cruiser
  • 2009 Arctic Cat 700 TRV Auto 2/4 WD IRS H1 Cruiser
  • 2010 Arctic Cat 700 TRV Auto 2/4 WD IRS H1 Cruiser
  • 2008 Arctic Cat 700 TRV Auto 2/4 WD IRS LE
  • 2010 Arctic Cat 700 TRV Auto 2/4 WD IRS S GT
  • 2010 Arctic Cat MUD PRO 1000
  • 2010 Arctic Cat MUD PRO 650
  • 2009 Arctic Cat MUD PRO 700
  • 2010 Arctic Cat MUD PRO 700
  • 2008 Arctic Cat Thundercat 1000
  • 2009 Arctic Cat Thundercat 1000
  • 2010 Arctic Cat Thundercat 1000
  • 2007 Can-Am Outlander 650
  • 2008 Can-Am Outlander 650
  • 2009 Can-Am Outlander 650
  • 2007 Can-Am Outlander 800
  • 2008 Can-Am Outlander 800
  • 2009 Can-Am Outlander 800R
  • 1996 Honda Foreman 400 4X4
  • 1997 Honda Foreman 400 4X4
  • 1998 Honda Foreman 400 4X4
  • 1999 Honda Foreman 400 4X4
  • 2000 Honda Foreman 400 4X4
  • 2001 Honda Foreman 400 4X4
  • 2002 Honda Foreman 400 4X4
  • 2003 Honda Foreman 400 4X4
  • 1998 Honda Foreman 450 ES 4x4
  • 1999 Honda Foreman 450 ES 4x4
  • 2000 Honda Foreman 450 ES 4x4
  • 2001 Honda Foreman 450 ES 4x4
  • 2002 Honda Foreman 450 ES 4x4
  • 2003 Honda Foreman 450 ES 4x4
  • 2004 Honda Foreman 450 ES 4x4
  • 1998 Honda Foreman 450 S 4X4
  • 1999 Honda Foreman 450 S 4X4
  • 2000 Honda Foreman 450 S 4X4
  • 2001 Honda Foreman 450 S 4X4
  • 2002 Honda Foreman 450 S 4X4
  • 2003 Honda Foreman 450 S 4X4
  • 2004 Honda Foreman 450 S 4X4
  • 2005 Honda Foreman 500 2x4 MAN
  • 2006 Honda Foreman 500 2x4 MAN
  • 2005 Honda Foreman 500 4X4 MAN
  • 2006 Honda Foreman 500 4X4 MAN
  • 2007 Honda Foreman 500 4X4 MAN
  • 2008 Honda Foreman 500 4X4 MAN
  • 2009 Honda Foreman 500 4X4 MAN
  • 2008 Honda Foreman 500 EPS 4x4 MAN
  • 2009 Honda Foreman 500 EPS 4x4 MAN
  • 2005 Honda Foreman 500 ES 4x4
  • 2006 Honda Foreman 500 ES 4x4
  • 2007 Honda Foreman 500 ES 4x4
  • 2008 Honda Foreman 500 ES 4x4
  • 2009 Honda Foreman 500 ES 4x4
  • 2007 Honda Foreman 500 ES EPS 4x4
  • 2008 Honda Foreman 500 ES EPS 4x4
  • 2009 Honda Foreman 500 ES EPS 4x4
  • 1999 Honda Fourtrax 300 2x4
  • 2000 Honda Fourtrax 300 2x4
  • 1995 Honda Fourtrax 300 4X4
  • 1996 Honda Fourtrax 300 4X4
  • 1997 Honda Fourtrax 300 4X4
  • 1998 Honda Fourtrax 300 4X4
  • 1999 Honda Fourtrax 300 4X4
  • 2000 Honda Fourtrax 300 4X4
  • 2000 Honda Rancher 350 ES 2x4
  • 2001 Honda Rancher 350 ES 2x4
  • 2002 Honda Rancher 350 ES 2x4
  • 2003 Honda Rancher 350 ES 2x4
  • 2004 Honda Rancher 350 ES 2x4
  • 2005 Honda Rancher 350 ES 2x4
  • 2006 Honda Rancher 350 ES 2x4
  • 2000 Honda Rancher 350 ES 4x4
  • 2001 Honda Rancher 350 ES 4x4
  • 2002 Honda Rancher 350 ES 4x4
  • 2003 Honda Rancher 350 ES 4x4
  • 2004 Honda Rancher 350 ES 4x4
  • 2005 Honda Rancher 350 ES 4x4
  • 2006 Honda Rancher 350 ES 4x4
  • 2000 Honda Rancher 350 S 2x4
  • 2001 Honda Rancher 350 S 2x4
  • 2002 Honda Rancher 350 S 2x4
  • 2003 Honda Rancher 350 S 2x4
  • 2004 Honda Rancher 350 S 2x4
  • 2005 Honda Rancher 350 S 2x4
  • 2006 Honda Rancher 350 S 2x4
  • 2000 Honda Rancher 350 S 4x4
  • 2001 Honda Rancher 350 S 4x4
  • 2002 Honda Rancher 350 S 4x4
  • 2003 Honda Rancher 350 S 4x4
  • 2004 Honda Rancher 350 S 4x4
  • 2005 Honda Rancher 350 S 4x4
  • 2006 Honda Rancher 350 S 4x4
  • 2004 Honda Rancher 400 AT 4x4
  • 2005 Honda Rancher 400 AT 4x4
  • 2006 Honda Rancher 400 AT 4x4
  • 2007 Honda Rancher 400 AT 4x4
  • 2007 Honda Rancher 420 2x4
  • 2008 Honda Rancher 420 2x4
  • 2009 Honda Rancher 420 2x4
  • 2010 Honda Rancher 420 2x4
  • 2007 Honda Rancher 420 4x4
  • 2008 Honda Rancher 420 4x4
  • 2009 Honda Rancher 420 4x4
  • 2010 Honda Rancher 420 4x4
  • 2009 Honda Rancher 420 AT 4x4
  • 2010 Honda Rancher 420 AT 4x4
  • 2009 Honda Rancher 420 AT EPS 4x4
  • 2010 Honda Rancher 420 AT EPS 4x4
  • 2009 Honda Rancher 420 EPS 4x4
  • 2010 Honda Rancher 420 EPS 4x4
  • 2007 Honda Rancher 420 ES 2x4
  • 2008 Honda Rancher 420 ES 2x4
  • 2009 Honda Rancher 420 ES 2x4
  • 2010 Honda Rancher 420 ES 2x4
  • 2007 Honda Rancher 420 ES 4x4
  • 2008 Honda Rancher 420 ES 4x4
  • 2009 Honda Rancher 420 ES 4x4
  • 2010 Honda Rancher 420 ES 4x4
  • 2009 Honda Rancher 420 ES EPS 4x4
  • 2010 Honda Rancher 420 ES EPS 4x4
  • 2003 Honda Rincon 650 4x4
  • 2004 Honda Rincon 650 4x4
  • 2005 Honda Rincon 650 4x4
  • 2006 Honda Rincon 680 4x4
  • 2007 Honda Rincon 680 4x4
  • 2008 Honda Rincon 680 4x4
  • 2009 Honda Rincon 680 4x4
  • 2010 Honda Rincon 680 4x4
  • 2001 Honda Rubicon 500 4x4 Auto
  • 2002 Honda Rubicon 500 4x4 Auto
  • 2003 Honda Rubicon 500 4x4 Auto
  • 2004 Honda Rubicon 500 4x4 Auto
  • 2005 Honda Rubicon 500 4x4 Auto
  • 2006 Honda Rubicon 500 4x4 Auto
  • 2007 Honda Rubicon 500 4x4 Auto
  • 2008 Honda Rubicon 500 4x4 Auto
  • 2009 Honda Rubicon 500 4x4 Auto
  • 2009 Honda Rubicon 500 EPS 4x4 Auto
  • 2005 Kawasaki Brute Force 650 4x4
  • 2006 Kawasaki Brute Force 650 4x4
  • 2007 Kawasaki Brute Force 650 4x4
  • 2008 Kawasaki Brute Force 650 4x4
  • 2009 Kawasaki Brute Force 650 4x4
  • 2010 Kawasaki Brute Force 650 4x4
  • 2011 Kawasaki Brute Force 650 4x4
  • 2006 Kawasaki Brute Force 650 4x4i
  • 2007 Kawasaki Brute Force 650 4x4i
  • 2008 Kawasaki Brute Force 650 4x4i
  • 2009 Kawasaki Brute Force 650 4x4i
  • 2010 Kawasaki Brute Force 650 4x4i
  • 2011 Kawasaki Brute Force 650 4x4i
  • 2005 Kawasaki Brute Force 750 4x4i
  • 2006 Kawasaki Brute Force 750 4x4i
  • 2007 Kawasaki Brute Force 750 4x4i
  • 2008 Kawasaki Brute Force 750 4x4i
  • 2009 Kawasaki Brute Force 750 4x4i
  • 2010 Kawasaki Brute Force 750 4x4i
  • 2011 Kawasaki Brute Force 750 4x4i
  • 2002 Kawasaki Prairie 650 4x4
  • 2003 Kawasaki Prairie 650 4x4
  • 2004 Kawasaki Prairie 700 4x4
  • 2005 Kawasaki Prairie 700 4x4
  • 2006 Kawasaki Prairie 700 4x4
  • 2008 Polaris RZR 800
  • 2009 Polaris RZR 800
  • 2010 Polaris RZR 800
  • 2011 Polaris RZR 800
  • 2011 Polaris RZR 800 EPS
  • 2007 Polaris Sportsman 500 EFI
  • 2009 Polaris Sportsman 500 EFI
  • 2005 Polaris Sportsman 500 HO
  • 2006 Polaris Sportsman 500 HO
  • 2008 Polaris Sportsman 500 HO
  • 2009 Polaris Sportsman 500 HO
  • 2010 Polaris Sportsman 500 HO
  • 2011 Polaris Sportsman 500 HO
  • 2006 Polaris Sportsman 500 HO EFI
  • 2008 Polaris Sportsman 500 HO EFI
  • 2011 Polaris Sportsman 550
  • 2010 Polaris Sportsman 550 EPS
  • 2009 Polaris Sportsman 550 XP
  • 2010 Polaris Sportsman 550 XP
  • 2011 Polaris Sportsman 550 XP EPS
  • 2005 Polaris Sportsman 700
  • 2006 Polaris Sportsman 700
  • 2005 Polaris Sportsman 700 EFI
  • 2006 Polaris Sportsman 700 EFI
  • 2007 Polaris Sportsman 700 EFI
  • 2005 Polaris Sportsman 800 EFI
  • 2006 Polaris Sportsman 800 EFI
  • 2007 Polaris Sportsman 800 EFI
  • 2010 Polaris Sportsman 800 EFI
  • 2011 Polaris Sportsman 800 EFI
  • 2008 Polaris Sportsman 800 HO EFI
  • 2009 Polaris Sportsman 800 HO EFI
  • 2009 Polaris Sportsman 850
  • 2010 Polaris Sportsman 850
  • 2011 Polaris Sportsman 850
  • 2010 Polaris Sportsman 850 EPS
  • 2011 Polaris Sportsman 850 EPS
  • 2007 Suzuki King Quad 450 AXi
  • 2008 Suzuki King Quad 450 AXi
  • 2009 Suzuki King Quad 450 AXi
  • 2010 Suzuki King Quad 450 AXi
  • 2009 Suzuki King Quad 500 AXi PS
  • 2006 Suzuki King Quad 700 4x4
  • 2007 Suzuki King Quad 700 4x4
  • 2008 Suzuki King Quad 750 AXi
  • 2009 Suzuki King Quad 750 AXi
  • 2000 Yamaha Big Bear 400 4x4
  • 2001 Yamaha Big Bear 400 4x4
  • 2002 Yamaha Big Bear 400 4x4
  • 2003 Yamaha Big Bear 400 4x4
  • 2004 Yamaha Big Bear 400 4x4
  • 2005 Yamaha Big Bear 400 4x4
  • 2006 Yamaha Big Bear 400 4x4
  • 2008 Yamaha Big Bear 400 4x4
  • 2009 Yamaha Big Bear 400 4x4
  • 2010 Yamaha Big Bear 400 4x4
  • 2007 Yamaha Big Bear 400 4x4 IRS
  • 2008 Yamaha Grizzly 350 4x4 IRS
  • 2009 Yamaha Grizzly 350 4x4 IRS
  • 2010 Yamaha Grizzly 350 4x4 IRS
  • 2011 Yamaha Grizzly 350 4x4 IRS
  • 2007 Yamaha Grizzly 450 4x4
  • 2008 Yamaha Grizzly 450 4x4
  • 2009 Yamaha Grizzly 450 4x4
  • 2010 Yamaha Grizzly 450 4x4
  • 2009 Yamaha Grizzly 550 4x4
  • 2002 Yamaha Grizzly 660 4x4
  • 2003 Yamaha Grizzly 660 4x4
  • 2004 Yamaha Grizzly 660 4x4
  • 2005 Yamaha Grizzly 660 4x4
  • 2006 Yamaha Grizzly 660 4x4
  • 2007 Yamaha Grizzly 660 4x4
  • 2008 Yamaha Grizzly 660 4x4
  • 2007 Yamaha Grizzly 700 4x4
  • 2008 Yamaha Grizzly 700 4x4
  • 2009 Yamaha Grizzly 700 4x4
  • 2010 Yamaha Grizzly 700 4x4
[All vehicle fits]
