High Lifter Front & Rear Lift Springs w/Tool for Arctic Cat Mud Pro 700/Thunder Cat 1000 (See Applications)
SKU: SPRTKIT-A1000Price: $275.85
APPLICATIONS:
ARCTIC CAT
ARCTIC CAT
400 (09-10)
450 (2010)
500 AUTO & MAN (08-09)
550 H1 (09-10)
550 TRV (09-10)
650 (2010)
650 TRV/TBX (2010)
650 MUD PRO (2010)
700 H1,TRV/TBX (09-10)
700 S,LTD, TBX (2010)
700 H1 & EFI (2008)
700 MUD PRO (09-11)
1000 MUD PRO (2010)
1000 THUNDER CAT (08-10)
FRONT & REAR SPRINGS WITH SPRING TOOL INCLUDED
