High Lifter Rear Spring Kit for Kawasaki Prairie 650/700, Brute Force 650 (See Apps)
Price: $72.95
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service.
 OEM springs tend to fatigue rapidly…even with low mileage. The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs. They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them.
And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock. For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity. The High Lifter Lift Springs are just what the doctor ordered!
Kawasaki 650 Prairie (2002-2003)
Kawasaki 650 Brute Force (05-13; SOLID REAR AXLE ONLY!)
Kawasaki 700 Prairie (2004-2007)
High Lifter Rear Spring Kit for Kawasaki Prairie 650/700, Brute Force 650 (See Apps) Reviews
High Lifter Warranties
High Lifter Rear Spring Kit for Kawasaki Prairie 650/700, Brute Force 650 (See Apps) fits the following vehicle(s):
  • 2005 Kawasaki Brute Force 650 4x4
  • 2006 Kawasaki Brute Force 650 4x4
  • 2007 Kawasaki Brute Force 650 4x4
  • 2008 Kawasaki Brute Force 650 4x4
  • 2009 Kawasaki Brute Force 650 4x4
  • 2010 Kawasaki Brute Force 650 4x4
  • 2011 Kawasaki Brute Force 650 4x4
  • 2012 Kawasaki Brute Force 650 4x4
  • 2013 Kawasaki Brute Force 650 4x4
  • 2002 Kawasaki Prairie 650 4x4
  • 2003 Kawasaki Prairie 650 4x4
[All vehicle fits]
