High Lifter Front & Rear Lift Springs for Polaris Sportsman 550/850 (See Applications)
Price: $238.90
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers.
Note: These springs do not work on Touring or X2 models.
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service. OEM springs tend to fatigue rapidly…even with low mileage. The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs.
They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock.
For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity.
These springs DO NOT work on touring or X2 models.
NOTE: The Polaris 2011-2014 Spring Adapter Kit (SPRP-ADAPTER) is required for High Lifter spring installation on 2011-2014 models that have the stamped steel spring adjustment collar instead of the old style aluminum adjustment collar Polaris has used.
Note: Powder-coating your springs will void any warranty. If you wish to change the color of your springs, you must use a different method of painting.
High Lifter Front & Rear Lift Springs for Polaris Sportsman 550/850 (See Applications) Reviews
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-1 of 1
1. Mike on 5/19/2013, said:
Strong springs. Took all the sag out that i had with stock springs in my polaris. Have many friends running these and they love them as well. Tool was a little helpful but could be designed better.
High Lifter Warranties
High Lifter Front & Rear Lift Springs for Polaris Sportsman 550/850 (See Applications) fits the following vehicle(s):
  • 2011 Polaris Sportsman 550
  • 2012 Polaris Sportsman 550
  • 2013 Polaris Sportsman 550
  • 2010 Polaris Sportsman 550 EPS
  • 2012 Polaris Sportsman 550 EPS
  • 2013 Polaris Sportsman 550 EPS
  • 2009 Polaris Sportsman 550 XP
  • 2010 Polaris Sportsman 550 XP
  • 2011 Polaris Sportsman 550 XP EPS
  • 2009 Polaris Sportsman 850
  • 2010 Polaris Sportsman 850
  • 2011 Polaris Sportsman 850
  • 2012 Polaris Sportsman 850
  • 2013 Polaris Sportsman 850
  • 2010 Polaris Sportsman 850 EPS
  • 2011 Polaris Sportsman 850 EPS
  • 2012 Polaris Sportsman 850 EPS
  • 2013 Polaris Sportsman 850 EPS
[All vehicle fits]
