High Lifter Front & Rear Lift Springs for Polaris Sportsman 400/500/570/600/700/800 (See Apps)
Price: $218.90
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers.
On 2011-2014 models, the Polaris Spring Adapter Kit (SPRP-ADAPTER) is required for High Lifter Spring installation on models that have the "new stamped steel" spring adjustment collar instead of the old style aluminum adjustment collar Polaris has always used.
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service. OEM springs tend to fatigue rapidly…even with low mileage. The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs.
They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock.
For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity.
The High Lifter Lift Springs are just what the doctor ordered!
Application
Polaris Sportsman EFI 500/600/700/800 (06-10)
Polaris Sportsman 400 (11-14)
Polaris Sportsman 500 (11-13)
Polaris Sportsman 570 (2013)
Polaris Sportsman 570 Touring (2014)
Polaris Sportsman 800 (11-14)
This kit will not work on X2 or touring models unless otherwise stated.
Note: Powder-coating your springs will void any warranty. If you wish to change the color of your springs, you must use a different method of painting.
High Lifter Front & Rear Lift Springs for Polaris Sportsman 400/500/570/600/700/800 (See Apps) Reviews
Product Rating: (5.00)   # of Ratings: 5   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-5 of 5
1. Francis on 5/16/2015, said:
Installed new springs on 2013 Polaris Sportsman 500HO.Installing fronts were easy,rears were a little more difficult.Had to purchase heavy duty spring compressor(for an automobile)from Autozone and grind down hooks to allow clearance from shock body for rear springs.They installed easy after that.You do need spring adapter kit for rear shocks.Went on a quick trail ride after install and they felt great.Haven't rode much due to busy schedule but I know i will be happy with them because of the type of riding I do,plus the yellow springs look great on my camo/black quad!I don't know how much lift I gained because I installed a 2 inch lift kit at same time I installed springs and never measured before and after.I'm sure there is some gain because stock springs were sloppy.Thanks Highlifter!!!!
2. Anonymous User on 5/4/2015, said:
Great springs should have put them on years ago !!!
3. Dan on 12/30/2014, said:
I put these on my 2014 Polaris Sportsman 570 Touring. They work wonderfully. I achieved just under 1.5 inches of lift above what the stock springs were. Installation for the rear springs took me about 90 minutes, and the front springs were about 4 hours because of the plastic that had to be removed. If I was to do it again, I would cut the plastic covers from inside the front trunk and access the top of the struts with an air impact gun and then glue a pvc cap over the holes, it would save 3 hours of hell. There was no loss of articulation from installing the heavier springs, no noise or grinding on the trail, and the ride felt smooth much like the stock springs did. You will notice that the High Lifter springs are at least 50% thicker than the stock springs. My machine required the use of one Adapter Kit for the rear springs only, they simply slide on first and give the spring a centered ring to fit over. They and the spring will only fit one way so it's not like you can mess up. If you have any questions, talk to Hunter in sales and he will answer all of your questions and take good care of you. Shipping was fast and no problems were encountered. I highly recommend this to all ATV enthusiasts who want to get the most out of their machine.
4. Matt on 12/3/2014, said:
Made a HUGE difference in capability and handling. Fronts went on great, rears were a bit tougher. Good quality paint also.
5. Jonathan on 3/16/2014, said:
Added lift to the bike. Were delivered at my house a couple days after ordering. Very happy.
High Lifter Warranties
High Lifter Front & Rear Lift Springs for Polaris Sportsman 400/500/570/600/700/800 (See Apps) fits the following vehicle(s):
  • 2011 Polaris Sportsman 400 HO 4x4
  • 2012 Polaris Sportsman 400 HO 4x4
  • 2013 Polaris Sportsman 400 HO 4x4
  • 2014 Polaris Sportsman 400 HO 4x4
  • 2007 Polaris Sportsman 500 EFI
  • 2009 Polaris Sportsman 500 EFI
  • 2006 Polaris Sportsman 500 HO
  • 2008 Polaris Sportsman 500 HO
  • 2009 Polaris Sportsman 500 HO
  • 2010 Polaris Sportsman 500 HO
  • 2011 Polaris Sportsman 500 HO
  • 2012 Polaris Sportsman 500 HO
  • 2013 Polaris Sportsman 500 HO
  • 2006 Polaris Sportsman 500 HO EFI
  • 2008 Polaris Sportsman 500 HO EFI
  • 2014 Polaris Sportsman 570
  • 2015 Polaris Sportsman 570
  • 2015 Polaris Sportsman 570 EPS
  • 2014 Polaris Sportsman 570 Touring
  • 2015 Polaris Sportsman 570 Touring
  • 2015 Polaris Sportsman 570 Touring EPS
  • 2006 Polaris Sportsman 700
  • 2006 Polaris Sportsman 700 EFI
  • 2007 Polaris Sportsman 700 EFI
  • 2006 Polaris Sportsman 800 EFI
  • 2007 Polaris Sportsman 800 EFI
  • 2010 Polaris Sportsman 800 EFI
  • 2011 Polaris Sportsman 800 EFI
  • 2012 Polaris Sportsman 800 EFI
  • 2013 Polaris Sportsman 800 EFI
  • 2014 Polaris Sportsman 800 EFI
  • 2012 Polaris Sportsman 800 EFI 6x6
  • 2008 Polaris Sportsman 800 HO EFI
  • 2009 Polaris Sportsman 800 HO EFI
[All vehicle fits]
