High Lifter Front & Rear Lift Springs for Polaris Ranger 500/700/800 Models (See Apps)
Price: $244.90
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers.
Note: Does Not Fit the HD Model. This kit does not work with the High Lifter Spring Tool.
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service. OEM springs tend to fatigue rapidly…even with low mileage. The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs.
They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock.
For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity.
The High Lifter Lift Springs are just what the doctor ordered!
APPLICATIONS:
Polaris 500 Ranger EFI 4X4 (2009)
Polaris 700 Ranger XP (2009; Does NOT fit Crew models)
Polaris 800 Ranger XP (2010)
Polaris 800 Ranger Crew (2010)
Polaris 800 Ranger XP (11-13) See 2011-2014 Fitment Notes Below
Polaris 800 Ranger Crew (11-14) See 2011-2014 Fitment Notes Below
NOTE: This kit does not work with Ranger HD models.
Fitment Note for 2011-2014 Models:
Our Polaris Spring Adapter Kit (SPRP-ADAPTER) is required for High Lifter Spring Installation on 2011-2014 Polaris models that have the new "stamped steel" spring adjustment collar instead of the old style aluminum adjustment collar Polaris has used in the past.
This kit does not work with the High Lifter Spring Installation tool.
Note: Powder-coating your springs will void any warranty. If you wish to change the color of your springs, you must use a different method of painting.
High Lifter Front & Rear Lift Springs for Polaris Ranger 500/700/800 Models (See Apps) Reviews
Product Rating: (4.67)   # of Ratings: 3   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-3 of 3
1. Anonymous User on 6/9/2015, said:
Ordering was quick and easy with no problems. Very professional and the packages arrived fast.
2. Anonymous User on 8/26/2014, said:
Really helps when ranger is loaded with corn for deer season
3. Anonymous User on 8/26/2014, said:
Really help s when hauling corn
High Lifter Warranties
High Lifter Front & Rear Lift Springs for Polaris Ranger 500/700/800 Models (See Apps) fits the following vehicle(s):
  • 2009 Polaris Ranger 500 EFI 4x4
  • 2010 Polaris Ranger 500 EFI 4x4
  • 2009 Polaris Ranger 700 4x4
  • 2010 Polaris Ranger 800 4x4
  • 2011 Polaris Ranger 800 4x4
  • 2012 Polaris Ranger 800 4x4
  • 2013 Polaris Ranger 800 4x4
  • 2011 Polaris Ranger 800 4x4 EPS
  • 2012 Polaris Ranger 800 4x4 EPS
  • 2010 Polaris Ranger 800 CREW 4x4
  • 2011 Polaris Ranger 800 CREW 4x4
  • 2012 Polaris Ranger 800 CREW 4x4
  • 2013 Polaris Ranger 800 CREW 4x4
  • 2014 Polaris Ranger 800 CREW 4x4
[All vehicle fits]
