High Lifter Rear Spring Kit for Arctic Cat 550/650/700 Prowler (See Applications)
SKU: SPRAR650P
Price: $148.95
APPLICATIONS:
ARCTIC CAT
550 PROWLER 09-10
650 PROWLER 06-09
700 PROWLER 08-10
OUR SPRING COMPRESSION TOOL CANNOT BE USED WITH THIS SPRING KIT YOU MUST USE AN AUTOMOTIVE GRADE SPRING COMPRESSION TOOL.
