High Lifter Rear Spring Kit for Arctic Cat 400i/500i/650i/700i (See Applications)
SKU: SPRAR4050
Price: $95.95
APPLICATIONS:
ARCTIC CAT
400i (2002-2007)
500i (2002-2007)
650V-TWIN (2004-2006)
650 H1 (2005-2007)
700 EFI (2006-2007)
