High Lifter Front Spring Kit for Arctic Cat 550/650/700 Prowler (See Apps)
Price:$128.95
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service.
OEM springs tend to fatigue rapidly…even with low mileage. The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs. They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock. For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity. The High Lifter Lift Springs are just what the doctor ordered!
APPLICATIONS:
ARCTIC CAT
Prowler 550 XT (09-13)
Prowler 650 (06-09)
Prowler 700 XTX (08-13)
NOTE: Our spring compression tool CANNOT be used with this spring kit. You must use an automotive grade spring compression tool.
High Lifter Front Spring Kit for Arctic Cat 550/650/700 Prowler (See Apps) Reviews
Customer Reviews
(0.00)
# of Ratings: 0
High Lifter Warranties
High Lifter Front Spring Kit for Arctic Cat 550/650/700 Prowler (See Apps) fits the following vehicle(s):
  • 2009 Arctic Cat Prowler 550 H1
  • 2010 Arctic Cat Prowler 550 XT
  • 2011 Arctic Cat Prowler 550 XT
  • 2012 Arctic Cat Prowler 550 XT
  • 2013 Arctic Cat Prowler 550 XT
  • 2014 Arctic Cat Prowler 550 XT
  • 2008 Arctic Cat Prowler 650
  • 2007 Arctic Cat Prowler 650 H1
  • 2008 Arctic Cat Prowler 650 XT
  • 2006 Arctic Cat Prowler 650 XT H1
  • 2007 Arctic Cat Prowler 650 XT H1
  • 2009 Arctic Cat Prowler 650 XT H1
  • 2009 Arctic Cat Prowler 700 XT H1 LE
  • 2008 Arctic Cat Prowler 700 XTX
  • 2010 Arctic Cat Prowler 700 XTX
  • 2011 Arctic Cat Prowler 700 XTX
  • 2012 Arctic Cat Prowler 700 XTX
  • 2013 Arctic Cat Prowler 700 XTX
  • 2014 Arctic Cat Prowler 700 XTX
  • 2009 Arctic Cat Prowler 700 XTX H1
[All vehicle fits]
