Pro Series Forward Control Arms for Polaris Ranger 400/500/570/700/800 Models (See Apps)
SKU: PSFAA-PR
Price: $229.95
The Pro Series Forward Control Arm Kit for Polaris Ranger EV, 400, 500, 700 XP, and 700 Ranger Crew features a laser-cut High Lifter logo in each A-Arm.
The Pro Series Forward Control Arm Kit is designed to allow fitment of larger tires on Polaris Rangers with the use of High Lifter 2” lift kits. The product is a redesigned a-arm that has a slightly different geometry (angle from the frame) that moves the axle, bottom of the strut, and wheel hub forward forward from the stock wheel mounting point. The result is a longer wheelbase and additional clearance behind the front tires so that the tire does not rub the lower inner fender.
There are 3 other advantages that the Pro Series Forward Control Arm Kit provides to riders of Polaris Rangers with oversized tires:
     a. In stock configuration the cv axle extends from the differential in not only a downward direction toward the wheel hub , it also angles slightly toward the rear, in essence a compound angle. In full lock turns, the load placed upon a CV joint is therefore considerably greater with the stock CV location than with the forward location provided by the new a-arm.
     b. The angle of attack when an obstruction is encountered is greater with the modification and therefore provides better mobility. In other words, the front tires get to the obstruction first and provides immediate traction, as compared to a front bumper meeting the obstruction first and restricting traction.
     c. When loaded in the bed of a pickup, the front tires and wheels meet the front of the bed first instead of the bumper meeting the cab or windshield. Note that this occurs in many modified ATVs but is NOT GUARANTEED. Different bumpers and winch mounting configurations determine this. The owner is entirely responsible for determining the safe loading for his own ATV and transportation.
Polaris Ranger EV (10-14)
Polaris 400 Ranger Mid-Size (10-14)
Polaris 500 Ranger 2x4 Full Size (05-09)
Polaris 500 Ranger 4x4 Full Size (05-08)
Polaris 500 Ranger EFI Mid-Size (11-13)
Polaris Ranger 500 Crew Mid-Size (11-13)
Polaris Ranger 570 Mid-Size (2014)
Polaris Ranger 570 Crew Mid-Size (2014)
Polaris Ranger 700 (05-08)
Polaris Ranger 700 6x6 (05-09)
Polaris Ranger 700 Crew (08-09)
Polaris Ranger 800 Mid-Size (13-14)
Only fits Rangers with strut front ends. Does not fit models with dual front A-Arms and shocks.
NOTE: If a customer is running or plans on running Front Outlaw DHT Axles and this forward a-arm kit, they will need to add the Polaris Steering Stop Kit (Part# RANGER-SSK) to avoid clearance issues on the CV boot.
Product Rating: (5.00)   # of Ratings: 3   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-3 of 3
1. Brannon on 11/29/2013, said:
Awesome fit
2. Anonymous User on 8/7/2013, said:
Parts are excellent. Actually has great instructructions. Polaris studs are a little short for spacers and longer studs are not offered. Also, was older machine so took some trial and error to get right spacers and lift arms to fit new tires. But even when part was ordered at 330PM the parts arrived next day UPS Every Sungle time! 2 of 3 of us were military with mechanic friend helper and quick turn on parts was worth double cost--but were actually cheaper. Parts signicigica you thicker and stronger with real grease zerts. Not found on any other unit we tried. Also tried another brand from NC. 3 times cost, not one instruction or picture in entire front rear suspension or wheel tire kit. After putting it together 3 times was obvious some parts were generic and not Polaris specific. Break out Metabo cutter and welder. Never did get them right, but they work. Go with pros who have done it 10+ years. Highlifter. And no I don't work with them, get paid, or get a discount. Just hate to see my brothers go through what I went through. Call them. Col D E Smith and Alam Gunn from Stockton AL. They can patch you to us and I'll tell you the truth. 26yr 4 mo 22 days military colonel. 5 combat yours and awards. No need to lie. Might as well have the best! Only place I'll shop!
3. Anonymous User on 3/29/2013, said:
Triangle ATV in Beaumont recommended you guy's and I have been very pleased with my new Highlifter forward A-arms for my Polaris Ranger 400.I do wish you would keep more inventory in stock to minimize back orders and wait time for future items. Thanks, Frank Arabie
