LIGHT LIFT
LIGHT LIFT
LIGHT LIFT
SKU: LTLIFT
Price: $28.95
The big center headlight on a Honda 400/450/450ES or 500 Rubicon is a great help when riding your ATV before daylight or after dark. You learn to depend on it, particularly when the small headlights in the fenders are covered with mud or blocked by a snow plow or other utility instrument. But, when you use the front rack, or worse, install a front basket with equipment or other items in the basket, the headlight gets blocked. Also, many times when an item is placed on the front rack, the glare from the light reflecting off of it can be distracting. The “Light Lift” raises the headlight up and the glare is reduced. The “Light Lift” is an inexpensive set of brackets, that when installed on your Honda, raise the center headlight 2-1/4” or 3-3/4”, depending on your needs. The kit includes complete instructions and hardware, giving back the use of the front basket and the headlight at the same time.
