Many stock ATVs come with a mediocre (at best) skid plate design. Usually, these consist of flimsy plastic that isn’t designed for OUR riding style. Now, there is an answer. The High Lifter Belly Plate is made of 3/16” Aluminum and is designed to fit the underside of your quad to provide protection to many fragile components that are susceptible to mud and obstacles that you can’t see (such as logs, rocks, and sticks under the surface). The High Lifter Belly Plates are custom designed and formed to provide maximum protection without sacrificing ground clearance. Screws are countersunk and installed from bottom up to fit flush so nothing hangs down to catch or drag on hazards. Drain holes are provided for oil drains and to help with clean-up after riding. APPLICATIONS: HONDA 350 RANCHER (00-03)
