TRD Gear Reduction for Honda Rancher 420 SRA/IRS (07-13), Honda Foreman 500 (05-13)
Price:$650.00
Options:
If you're looking to give your ATV extra pulling power by increasing torque then a gear reduction kit is the way to go! While an ATV may be a great performer on the trail with stock tire height, when larger mud tires are added for use in extreme conditions this can often leave a performance enthusiast wishing for more low end grunt. You can overcome this problem by using a gear reduction kit. A reduction kit is designed so that a stock ATV can turn the larger more aggressive mud tires without additional costly engine modifications.
This kit provides a 21% gear reduction.
Once you install a gear reduction kit the motor doesn't have to work as hard to spin the wheel which means it won't draw as much current from your batteries while it simultaneously increases torque to provide you with the traction and pulling power that you need.
The system requires approximately 4-5 hours of labor by an experienced technician to install and is furnished complete with pictures and instructions. After installation, the RPM will be slightly increased, even with oversized tires. Tests have shown this increased RPM has not been objectionable. Gas mileage is essentially the same as the machine would get without the gear reduction system and with oversize tires installed. This product is carefully machined and heat treated for durability and long life.
This kit provides a 21% gear reduction on the Rancher and Foreman models listed below.
NOTE: This kit is designed for 29.5" tires and does NOT fit the Honda Rubicon 500.
APPLICATIONS
TRD Gear Reduction for Honda Rancher 420 SRA/IRS (07-13), Honda Foreman 500 (05-13) Reviews
Customer Reviews
(5.00)
# of Ratings: 1
1. on 9/24/2014, said:
Seems to be solidly made although a little pricey but it does what it's meant to do. Instructions need some improvement-both in accuracy and picturewise (black and white low resolution and areas to clearance) If you're attempting this GR and have even a little mechanical knowledge you should be fine-just take your time. Note: Online says designed for the 29.5 outlaws...instructions say this GR puts you at the low end which I take to mean just enough of a GR to turn them. Seems to be that shift points are on par with factory tires and gears (Im running 28x12x12 Gorilla Silverbacks; also from HL) Haven't had them in thick mud for a full test
(5 people found this comment helpful, 1 did not)
Showing comments 1-1 of 1
High Lifter Warranties
TRD Gear Reduction for Honda Rancher 420 SRA/IRS (07-13), Honda Foreman 500 (05-13) fits the following vehicle(s):
  • 2014 Honda Foreman 500 4x4
  • 2015 Honda Foreman 500 4x4
  • 2005 Honda Foreman 500 4X4 MAN
  • 2006 Honda Foreman 500 4X4 MAN
  • 2007 Honda Foreman 500 4X4 MAN
  • 2008 Honda Foreman 500 4X4 MAN
  • 2009 Honda Foreman 500 4X4 MAN
  • 2011 Honda Foreman 500 4X4 MAN
  • 2012 Honda Foreman 500 4X4 MAN
  • 2013 Honda Foreman 500 4X4 MAN
  • 2014 Honda Foreman 500 4x4 PS
  • 2015 Honda Foreman 500 EPS 4x4
  • 2008 Honda Foreman 500 EPS 4x4 MAN
  • 2009 Honda Foreman 500 EPS 4x4 MAN
  • 2011 Honda Foreman 500 EPS 4x4 MAN
  • 2012 Honda Foreman 500 EPS 4x4 MAN
  • 2013 Honda Foreman 500 EPS 4x4 MAN
  • 2005 Honda Foreman 500 ES 4x4
  • 2006 Honda Foreman 500 ES 4x4
  • 2007 Honda Foreman 500 ES 4x4
  • 2008 Honda Foreman 500 ES 4x4
  • 2009 Honda Foreman 500 ES 4x4
  • 2011 Honda Foreman 500 ES 4x4
  • 2012 Honda Foreman 500 ES 4x4
  • 2013 Honda Foreman 500 ES 4x4
  • 2014 Honda Foreman 500 ES 4x4
  • 2015 Honda Foreman 500 ES 4x4
  • 2014 Honda Foreman 500 ES 4x4 PS
  • 2007 Honda Foreman 500 ES EPS 4x4
  • 2008 Honda Foreman 500 ES EPS 4x4
  • 2009 Honda Foreman 500 ES EPS 4x4
  • 2012 Honda Foreman 500 ES EPS 4x4
  • 2013 Honda Foreman 500 ES EPS 4x4
  • 2015 Honda Foreman 500 ES EPS 4x4
  • 2007 Honda Rancher 420 2x4
  • 2008 Honda Rancher 420 2x4
  • 2009 Honda Rancher 420 2x4
  • 2010 Honda Rancher 420 2x4
  • 2011 Honda Rancher 420 2x4
  • 2012 Honda Rancher 420 2x4
  • 2014 Honda Rancher 420 2x4
  • 2015 Honda Rancher 420 2x4
  • 2007 Honda Rancher 420 4x4
  • 2008 Honda Rancher 420 4x4
  • 2009 Honda Rancher 420 4x4
  • 2010 Honda Rancher 420 4x4
  • 2011 Honda Rancher 420 4x4
  • 2012 Honda Rancher 420 4x4
  • 2014 Honda Rancher 420 4x4
  • 2015 Honda Rancher 420 4x4
  • 2014 Honda Rancher 420 4x4 PS
  • 2009 Honda Rancher 420 AT 4x4
  • 2010 Honda Rancher 420 AT 4x4
  • 2011 Honda Rancher 420 AT 4x4
  • 2012 Honda Rancher 420 AT 4x4
  • 2014 Honda Rancher 420 AT 4x4
  • 2014 Honda Rancher 420 AT 4x4 PS
  • 2009 Honda Rancher 420 AT EPS 4x4
  • 2010 Honda Rancher 420 AT EPS 4x4
  • 2011 Honda Rancher 420 AT EPS 4x4
  • 2012 Honda Rancher 420 AT EPS 4x4
  • 2014 Honda Rancher 420 Auto DCT 4x4
  • 2015 Honda Rancher 420 Auto DCT 4x4
  • 2015 Honda Rancher 420 Auto DCT EPS 4x4
  • 2014 Honda Rancher 420 Auto DCT PS 4x4
  • 2009 Honda Rancher 420 EPS 4x4
  • 2010 Honda Rancher 420 EPS 4x4
  • 2011 Honda Rancher 420 EPS 4x4
  • 2012 Honda Rancher 420 EPS 4x4
  • 2015 Honda Rancher 420 EPS 4x4
  • 2007 Honda Rancher 420 ES 2x4
  • 2008 Honda Rancher 420 ES 2x4
  • 2009 Honda Rancher 420 ES 2x4
  • 2010 Honda Rancher 420 ES 2x4
  • 2011 Honda Rancher 420 ES 2x4
  • 2012 Honda Rancher 420 ES 2x4
  • 2014 Honda Rancher 420 ES 2x4
  • 2015 Honda Rancher 420 ES 2x4
  • 2007 Honda Rancher 420 ES 4x4
  • 2008 Honda Rancher 420 ES 4x4
  • 2009 Honda Rancher 420 ES 4x4
  • 2010 Honda Rancher 420 ES 4x4
  • 2011 Honda Rancher 420 ES 4x4
  • 2012 Honda Rancher 420 ES 4x4
  • 2014 Honda Rancher 420 ES 4x4
  • 2015 Honda Rancher 420 ES 4x4
  • 2009 Honda Rancher 420 ES EPS 4x4
  • 2010 Honda Rancher 420 ES EPS 4x4
  • 2011 Honda Rancher 420 ES EPS 4x4
  • 2012 Honda Rancher 420 ES EPS 4x4
  • 2015 Honda Rancher 420 IRS Auto DCT
  • 2015 Honda Rancher 420 IRS Auto DCT EPS
[All vehicle fits]
