High Lifter Front Spring Lift Kit for Polaris Sportsman 335/400/500/600/700 (Used w/Progressive Front Sping Kit Only)
SKU: PLK335/500-10
Price: $24.95
Note: The Polaris Front Spring Lift Kit is to be used with the Progressive Front Spring Kit. Do not purchase this product along. It will not work without the Progressive Front Spring Kit.
Polaris 2” Lift Kit
2” Lift Kit Features:
·         Zinc plated
·         Front and rear lift
Polaris Sportsman 335/400/500/600/700 (Front)
