Fender Kit for Polaris 800 RZR (09-12)
SKU: FKITPRZR
Price: $184.95
Want to modify your RZR with over-sized tires but concerned about clearance issues between large front tires and factory fender support brackets? Use the High Lifter Fender Kit to move fender support from under the wheel well and provide the additional clearance you need to turn your RZR into the monster you’ve always wanted! This kit is designed to allow you to run up to a 29.5" Outlaw on a 09-12 Polaris RZR with a High Lifter spring kit installed.
APPLICATIONS: Polaris RZR 800 (09-12)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-1 of 1
1. lee on 4/7/2012, said:
awesome took hour a side to install using a dremel tool cut off wheel i also used bead of black windshield urethane before bolting them on looks and works fantastic no more tire rubbing for me
