Polaris RZR 1000 XP 4 EPS Max Clearance Lower Arched Radius Bar for Polaris RZR 1000 XP - (Select Color)
Price:$169.95
Options:
A bent rear radius bar on your RZR 1000 XP will hinder your ground clearance and can quickly lead to getting stuck because you’re hung in a rut or on a rock or a shortened ride. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Max Clearance Series Radius Bar.
Want to upgrade your upper and lower radius bars? Check out the Max Clearance Series Radius Bar's companion with the Upper Straight Radius Bar (PSRA-RZR1-1-R).
A bent rear radius bar on your RZR 1000 XP will hinder your ground clearance and can quickly lead to a broken ride or getting stuck because you’re hung in a rut or on a rock. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Arched Radius Bar.
Made from 1 ¼” x 3/16” DOM steel tubing, the Max Clearance Series Radius Bar is a beefy addition compared to the OEM bars (3/4”) and other competitors (1”). The simple bolt-on kit also features a 5/8” heim joint with a load rated at 17,955 pounds and polyurethane bushings for rugged durability in the deepest ruts and along the rockiest terrain.
When comparing the Max Clearance Series Radius Bar to the competitors, you’ll notice that ours give the MOST ground clearance across the entire bar and the most strength. Something you won’t find anywhere else. You didn’t spend $20,000 on the BEST UTV on the market to save a few bucks on a weak link! High Lifter’s Max Clearance Series Radius Bar will give you the strength and clearance needed for peace of mind when riding the trails!
Product features:
-          Extreme arches for maximum ground clearance.
-          1 ¼” x 3/16” DOM steel tubing
-          5/8” heim joint with a load rating of 17,955 pounds
-          Polyurethane bushings
-          Simple bolt-on kit
-          Instructions complete with photos for a quick install
Note: If you are running the lower radius bar kit with the stock trailing arm, you will need to trim the trailing arm. Instructions  for this are included in the product manual.
Polaris RZR 1000 XP 4 EPS Max Clearance Lower Arched Radius Bar for Polaris RZR 1000 XP - (Select Color) Reviews
Customer Reviews
(0.00)
# of Ratings: 0
High Lifter Warranties
Polaris RZR 1000 XP 4 EPS Max Clearance Lower Arched Radius Bar for Polaris RZR 1000 XP - (Select Color) fits the following vehicle(s):
  • 2016 Polaris RZR 1000 4 High Lifter Edition
  • 2017 Polaris RZR 1000 4 High Lifter Edition
  • 2014 Polaris RZR 1000 XP
  • 2014 Polaris RZR 1000 XP 4
  • 2015 Polaris RZR 1000 XP 4 EPS
  • 2016 Polaris RZR 1000 XP 4 EPS
  • 2017 Polaris RZR 1000 XP 4 EPS
  • 2015 Polaris RZR 1000 XP EPS
  • 2016 Polaris RZR 1000 XP EPS
  • 2017 Polaris RzR 1000 XP EPS
  • 2015 Polaris RZR 1000 XP High Lifter
  • 2016 Polaris RZR 1000 XP High Lifter Edition
  • 2017 Polaris RZR 1000 XP High Lifter Edition
  • 2017 Polaris RZR 1000 XP SE EPS
  • 2016 Polaris RZR TURBO 4
  • 2016 Polaris RZR TURBO XP EPS
[All vehicle fits]
