High Lifter Signature Series 4" Lift Kit for Can-Am Maverick 1000 (14-15)
Price:$489.95
Options:
Relocate your shock mounts and get the lift need for tighter suspension and larger mud tires! Our lift consistently measures truer (and higher) than the competition! This 4" kit addresses sway bar issues and provides new linkage with heavy duty heim joints to allow for proper function of the sway bar - something competitors do not address!
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 4” Signature Series Lift Kit. Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain. Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit. The product? The Signature Series Lift Kit is even easier to install with a bolt-on application that consistently measures truer over competitor products.
Our 4” Signature Series Lift Kit for the Can-Am Maverick 1000 takes UTV lift kits to a new level of strength and durability. The front lift brackets are precision welded from ¼” American-made steel, while the rear plates are crafted from 3/8” American-made steel. Each part in the kit is precision CNC laser cut, CNC bent, and CNC machined – a guarantee that your kit will fit just like our engineers designed it to be.
In addition to the heavy-duty steel used in our brackets, our research and development team crafted new offset sway bar linkage that allows us to achieve additional lift without removing the sway bar. When combined with the heavy duty heims on the offset sway bar link, we’re able to achieve a 4” lift using stock axles – something the competitors cannot do!
4” Signature Series Lift Kit Features:
·         All hardware needed for successful installation
·         High Lifter logo precision laser cut into each kit
·         User-friendly instructions
·         Bolt-on application; takes approximately 1-2 hours for install
·         Powder-coated and plated for durability
·         Front and rear lift
Tire Fitment:
Can-Am Maverick 1000 STD & XRS - Up to 35"
Can-Am Maverick 1000 XRS & XRS-DPS (14-15)
Can-Am Maverick 1000 STD (14-15)
High Lifter Signature Series 4" Lift Kit for Can-Am Maverick 1000 (14-15) Reviews
Customer Reviews
(4.00)
# of Ratings: 1
1. on 1/10/2017, said:
I received this lift in a very timely manner. I installed almost right away. The lift brackets are solid. This lift raised my bike as much as I was expecting and haven't had a any issues so far. The only thing I haven't addressed with highlighter is that the bolts for the emblem jammed when I was installing them and I had to cut the bolts off. Also there is an extra hole in the front brackets. For some reason there are no bolts with the lift to add the extra bolts. Otherwise, quick and painless install.
Showing comments 1-1 of 1
High Lifter Warranties
High Lifter Signature Series 4" Lift Kit for Can-Am Maverick 1000 (14-15) fits the following vehicle(s):
  • 2014 Can-Am Maverick 1000
  • 2015 Can-Am Maverick 1000
  • 2016 Can-Am Maverick 1000
  • 2016 Can-Am Maverick 1000 DPS
  • 2014 Can-Am Maverick 1000 XRS
  • 2015 Can-Am Maverick 1000 XRS
  • 2014 Can-Am Maverick 1000 XRS-DPS
  • 2015 Can-Am Maverick 1000 XRS-DPS
[All vehicle fits]
