High Lifter Riser Snorkel Polaris Ranger 900
Price:$265.95
Options:
High Lifter makes the highest quality and most comprehensive snorkel kit in the ATV industry.  Our Diver Down Snorkels are the best looking and most professional appearing kits on the market.  From fit to finish, to the level of detail, our kits are not only built to work, they are built to look good while doing it.
NOTES: This kit will work with a back glass installed.
This kit does not work on 2017 models due to the addition of a third drain plug.
This Diver Down Snorkel kit contains everything you need to properly snorkel your ride.
  • Custom Powder Coated Riser Bracket to keep risers straight, evenly spaced and looking good
  • Rubber Grommets to hold riser tubes in place
  • 1 ½”, 2” or 3” Risers - based on specific model
  • Heavy Duty Vinyl Tubing to route difficult locations where the competition uses think tubing
  • High Heat Silicon Hose in those critical areas where the competition melts
  • Bellows to keep water out of differentials and transmission
  • All mounting hardware for complete installation
  • Step-by-step instructions complete with detailed photos
Benefits:
  • Provides clean, dry air to the engine and other parts needing venting
  • Prevents mud, water and debris from entering the engine and clutch housings when equipped
  • Bellows allow the differential and transmission air  to expand and contract without the need for long vent lines that can easily get plugged with mud or be pulled off
  • Each Kit is engineered and  cut to fit your specific application
FAQ
Why Snorkel? Simply put – The right snorkel can be the best insurance you buy for your ATV or UTV.  The right snorkel can protect you expensive investment from disaster when submerged deeper than OE rated water depth.  On the other hand, the wrong snorkel can be your worst investment and nightmare.  We’ve seen countless units come through our shop with leaking snorkels
How could that happen?  Snorkels leak for a variety of reasons.  Installation errors account for a lot these.  Many times a do-it-yourselfer may get it right, but only for a short time.  When pipes aren’t cut to correct length and things don’t line up quite right, many times the snorkel will prevent water, but only for a limited time, then the joint fails.  One of the most common that we’ve seen is failure due to a heat source.  When the snorkel runs close to heat source the snorkel material deteriorates during each ride.  The material gets harder and more brittle and many times begins to deform.  At some point the material cracks and begins to let mud and water in.  Less expensive kits rarely provide the heat resistant material to account for this.  Our goal is to avoid these areas.  This can take more time and more material, but goes a long way to extending the life of the snorkel and the ATV/UTV.
What does a Snorkel do? A snorkel kit is intended to provide clean, dry air to the engine and other parts needing venting on ATVs/UTVs such as clutches, differentials, transmission, carburetors and fuel tanks.  This doesn’t necessarily mean the ATV/UTV should exceed the OE manufacturer’s stated maximum rated water line depth. The snorkel kit is intended as additional margin of protection in the event that the ATV/UTV is inadvertently driven into water deeper than the OE manufacturer’s air intakes will tolerate. There are many considerations to make when increasing water line depth and a snorkel is just one component.
We know a little about taking off-road vehicles to the extreme - especially when it comes to deep water and mud. Trust us to protect your ride from deep water hazards with Diver Down Snorkels by High Lifter Products.
High Lifter Riser Snorkel Polaris Ranger 900 Reviews
Customer Reviews
(4.58)
# of Ratings: 12
1. on 12/28/2016, said:
Bought this for a customers ranger 900. We put it on for him and it fit great. Customer was very pleased with his new ranger for Christmas.
2. on 11/24/2016, said:
THIS KIT IS AWESOME....Installed it without a problem, its as easy as paint by numbers
(1 people found this comment helpful, 0 did not)
3. on 10/26/2016, said:
Piping was standard pvc plumbing pipe. The piping was quite a bit smaller in diameter than the piping on my ranger which would cause a restriction in air flow.
4. on 10/20/2016, said:
great product i recoment it to everyone that has one also easy to install
5. on 10/20/2016, said:
Cleanest and best designed snorkel kit I have seen out there om the market.
7. on 9/29/2016, said:
There was a form I filled out that said when I make my purchase I would receive a free drinking bottle. I phone because it was not there and was told you would send. I see you have let me down and have not sent it. Not sure I will deal with your company again or tell any of my friends about you. I belong to a ATV club of over 300 members. So sad and cheap of you.
(1 people found this comment helpful, 1 did not)
8. on 9/7/2016, said:
Great product easy installation step by step instructions had mine done in about 2 hours
9. on 7/14/2016, said:
Great product super easy install the instructions that came with the product were ez to comprehend would recommend this product too any one looking everything that came in the kit are high grade and look top notch highlighter out did themselves on this product a++++
10. on 7/8/2016, said:
Purchased for my 2016 ranger crew xp900. Works and fit perfectly. The Lazer cut bracket adds a nice touch. Instructions were on point with good pictures to aid in installation. Could be a little taller to the top of the snorkels. End caps are also nice.
Showing comments 1-10 of 12 (Next 10)
Click Here to see all comments
Instruction manuals for this product are not available online due to proprietary information. Instructions are included in the box that will be shipped to you. If you have ordered a kit and need additional instructions, please contact your salesman at 800.699.0947.
High Lifter Warranties
High Lifter Riser Snorkel Polaris Ranger 900 fits the following vehicle(s):
  • 2014 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 CREW EPS
  • 2013 Polaris Ranger 900 XP
  • 2014 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP
  • 2016 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP EPS
  • 2016 Polaris Ranger 900-5 Crew EPS
  • 2016 Polaris Ranger 900-6 Crew EPS
[All vehicle fits]
