High Lifter Signature Series Lift Kit for Can-Am Outlander MAX 500/650/800/1000 (See Applications)
Price: $189.95
Options:
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 2” Signature Series Lift Kit. Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain. Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit. The product? The Signature Series Lift Kit is even easier to install with a bolt-on application that consistently measures truer over competitor products.
The High Lifter 2” Signature Series Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension. Each Lift Kit part is precision cut and zinc plated for durability and reliability in any environment. The front portion of this lift consists of 1" spring spacers only. The rear portion of the lift is a bracket lift.
2” Signature Series Lift Kit Features:
·         All hardware needed for successful installation
·         High Lifter logo precision laser cut into each kit
·         User-friendly instructions
·         Bolt-on application; takes approximately 1-2 hours for install
·         Zinc plated
·         Front 1" Spring Spacers, Rear Bracket Lift
Tire Fitment:
Can-Am 500 Outlander MAX STD, DPS, XT - Up to 30"
Can-Am 650 Outlander MAX STD, DPS, XT - Up to 30"
Can-Am 800 Outlander MAX EFI, DPS, XT - Up to 30"
Can-Am 1000 Outlander MAX DPS, XT, LTD - Up to 30"
Can-Am 500 Outlander MAX STD, DPS, XT (13-14)
Can-Am 500 Outlander MAX DPS (2015)
Can-Am 650 Outlander MAX STD, DPS, XT (13-14)
Can-Am 650 Outlander MAX STD, DPS (2015)
Can-Am 800 Outlander MAX EFI, DPS, XT (13-15)
Can-Am 1000 Outlander MAX DPS, XT, LTD (13-15)
Note: If running Outlaw DHT Axles and this lift kit, you need to remove the rear axle spacer as shown in the instructions. If running this lift kit with stock axles, the rear axle spacer is still needed. Please refer to the instruction manual for further information.
High Lifter Signature Series Lift Kit for Can-Am Outlander MAX 500/650/800/1000 (See Applications) Reviews
High Lifter Warranties
High Lifter Signature Series Lift Kit for Can-Am Outlander MAX 500/650/800/1000 (See Applications) fits the following vehicle(s):
  • 2013 Can-Am Outlander 1000 MAX DPS
  • 2014 Can-Am Outlander 1000 MAX DPS
  • 2015 Can-Am Outlander 1000 MAX DPS
  • 2013 Can-Am Outlander 1000 MAX LTD
  • 2014 Can-Am Outlander 1000 MAX LTD
  • 2015 Can-Am Outlander 1000 MAX LTD
  • 2016 Can-Am Outlander 1000 MAX LTD
  • 2013 Can-Am Outlander 1000 MAX XT
  • 2014 Can-Am Outlander 1000 MAX XT
  • 2015 Can-Am Outlander 1000 MAX XT
  • 2016 Can-Am Outlander 1000 MAX XT
  • 2014 Can-Am Outlander 500 MAX
  • 2013 Can-Am Outlander 500 MAX DPS
  • 2014 Can-Am Outlander 500 MAX DPS
  • 2015 Can-Am Outlander 500 MAX DPS
  • 2016 Can-Am Outlander 570 MAX DPS
  • 2016 Can-Am Outlander 570 MAX XT
  • 2014 Can-Am Outlander 650 MAX
  • 2015 Can-Am Outlander 650 MAX
  • 2013 Can-Am Outlander 650 MAX DPS
  • 2014 Can-Am Outlander 650 MAX DPS
  • 2015 Can-Am Outlander 650 MAX DPS
  • 2016 Can-Am Outlander 650 MAX DPS
  • 2014 Can-Am Outlander 650 MAX X
  • 2013 Can-Am Outlander 650 MAX XT
  • 2016 Can-Am Outlander 650 MAX XT
  • 2013 Can-Am Outlander 800 MAX DPS
  • 2014 Can-Am Outlander 800R MAX DPS
  • 2013 Can-Am Outlander 800R MAX XT
  • 2014 Can-Am Outlander 800R MAX XT
  • 2015 Can-Am Outlander 800R MAX XT
  • 2016 Can-Am Outlander 850 MAX XT
[All vehicle fits]
