High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew
Price:$169.95
Options:
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 4” Signature Series Lift Kit.  Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain.  Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit.  The product?  An easy-to-install, bolt-on lift that consistently measures truer over competitor products.
The High Lifter 4” Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension.  Each Lift Kit part  is precision cut and zinc plated for durability and reliability in any environment.
4” Lift Kit Features:
 - All hardware needed for successful installation
 - User-friendly instructions
 - Bolt-on application; takes approximately 1-2 hours for install
 - Zinc plated
 - Front and rear lift
 - Clear-coated High Lifter name plate
High Lifter's Steering Stops (RANGER-SSK) are a must-have for Ranger Lift Kit owners. The Steering Stops helps reduce the turn radius and can help prevent breaking an axle. Click HERE to add a set of Steering Stops to your order today!
NOTES: This lift kit will not fit any 2016 570 XP Full Size Ranger with front strut suspension. This lift kit will not fit the Polaris Ranger Northstar Edition.
Tire Fitment:
Polaris 900 Ranger XP - Up to 27"
Polaris 900 Ranger Crew - Up to 27"
Notes:
1.5" spacers are required in the rear if you are running factory 900 Ranger steel wheels.
High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew Reviews
Customer Reviews
(4.74)
# of Ratings: 19
1. on 2/15/2017, said:
Easy install and fast shipping. Directions was easy to follow and it helped my ground clearance tremendously! Highly recommended and you won't find a better price.
2. on 2/3/2017, said:
Easy install! Works great!
4. on 1/14/2017, said:
Very fast shipping, quality parts, fits perfect
5. on 1/3/2017, said:
Installation was minimal and this lift gave me the ground clearance I wanted. Good job High Lifter, quality products.
7. on 1/2/2017, said:
It's looks like a completely different ranger with the lift kit, tires and wheels I put on it! Now I just need to save more money up so I can order the forward A arms from y'all as well
8. on 12/31/2016, said:
Your sales people really under sold this item! They are a lot better in person and on the unit then you can see in the pictures. Love them ! See you at mud nationals 2017!!!!!!
10. on 12/3/2016, said:
The kit was easily installed with the detailed instructions provided. It's a true 4" lift on my Ranger. Very good product.
Showing comments 1-10 of 18 (Next 10)
Click Here to see all comments
High Lifter Warranties
High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew fits the following vehicle(s):
  • 2017 Polaris Ranger 1000
  • 2017 Polaris Ranger 1000 Crew
  • 2017 Polaris Ranger 1000 Crew EPS
  • 2016 Polaris Ranger 1000 DSL
  • 2016 Polaris Ranger 1000 DSL Crew
  • 2017 Polaris Ranger 1000 EPS
  • 2015 Polaris Ranger 570 Crew Full Size
  • 2015 Polaris Ranger 570 Crew Full Size EPS
  • 2015 Polaris Ranger 570 Full Size
  • 2016 Polaris Ranger 570 Full Size
  • 2016 Polaris Ranger 570-4 Crew
  • 2016 Polaris Ranger 570-6 Crew
  • 2017 Polaris Ranger 900
  • 2014 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 Crew
  • 2017 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 CREW EPS
  • 2017 Polaris Ranger 900 Crew EPS
  • 2017 Polaris Ranger 900 EPS
  • 2013 Polaris Ranger 900 XP
  • 2014 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP
  • 2016 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP EPS
  • 2016 Polaris Ranger 900-5 Crew EPS
  • 2016 Polaris Ranger 900-6 Crew EPS
  • 2015 Polaris Ranger Diesel
  • 2015 Polaris Ranger Diesel Crew
  • 2017 Polaris Ranger DSL
  • 2017 Polaris Ranger DSL Crew
[All vehicle fits]
