High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew (13-14)
Price: $159.95
Options:
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 4” Signature Series Lift Kit.  Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain.  Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit.  The product?  An easy-to-install, bolt-on lift that consistently measures truer over competitor products.
The High Lifter 4” Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension.  Each Lift Kit part  is precision cut and zinc plated for durability and reliability in any environment.
4” Lift Kit Features:
 - All hardware needed for successful installation
 - User-friendly instructions
 - Bolt-on application; takes approximately 1-2 hours for install
 - Zinc plated
 - Front and rear lift
 - Clear-coated High Lifter name plate
High Lifter's Steering Stops (RANGER-SSK) are a must-have for Ranger Lift Kit owners. The Steering Stops helps reduce the turn radius and can help prevent breaking an axle. Click HERE to add a set of Steering Stops to your order today!
Tire Fitment:
Polaris 900 Ranger XP - Up to 28"
Polaris 900 Ranger Crew - Up to 28"
Polaris 900 Ranger XP (13-14)
Polaris 900 Ranger Crew (2014)
Notes:
1.5" spacers are required in the rear if you are running factory 900 Ranger steel wheels.
High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew (13-14) Reviews
Product Rating: (4.89)   # of Ratings: 28   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-10 of 21 (Next 10) Click Here to see all comments
1. Anonymous User on 5/14/2015, said:
Easily installed with hand tools. Fit is excellent and works perfect. Only suggestion - steering stops need to be included or at least suggested during purchase.
2. Anonymous User on 5/12/2015, said:
Great product easy to install
3. Anonymous User on 5/7/2015, said:
High quality customer favorite!!
4. Anonymous User on 4/16/2015, said:
Everything went smoothly and fit together great.
5. Anonymous User on 1/14/2015, said:
Installed a 4" high lifter kit on my Polaris ep 900 Crewcab. Incredible difference and the installation took about an hour and a half. Pretty good for a rookie like me. jem
6. Anonymous User on 1/5/2015, said:
Thanks for the help in selecting the 4 inch highlifter bracket lift for my ranger 900, it was very simple to instal, and rides just as smooth or better than it did factory. Highlifter staff was great and I received my order in under 2 days... Thanks again Justin Ayres
Was this comment helpful? yes no   (2 people found this comment helpful, 0 did not)
7. Anonymous User on 12/23/2014, said:
Really easy to put on and its super strong I ride my side by side hard and its held up
8. Anonymous User on 12/8/2014, said:
Thanks for the great service
9. Anonymous User on 11/18/2014, said:
Very easy to install and fast shipping
10. Anonymous User on 8/25/2014, said:
Excellent quality and fitment was perfect, defiantly worth the money good product!!
High Lifter Warranties
High Lifter Signature Series 4" Lift Kit for Polaris Ranger 900 XP, Ranger 900 Crew (13-14) fits the following vehicle(s):
  • 2015 Polaris Ranger 570 Crew Full Size
  • 2015 Polaris Ranger 570 Crew Full Size EPS
  • 2015 Polaris Ranger 570 Full Size
  • 2014 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 Crew
  • 2015 Polaris Ranger 900 CREW EPS
  • 2013 Polaris Ranger 900 XP
  • 2014 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP
  • 2015 Polaris Ranger 900 XP EPS
  • 2015 Polaris Ranger Diesel
  • 2015 Polaris Ranger Diesel Crew
[All vehicle fits]
