Max Clearance Front Lower Control Arms for Polaris RZR 900 XP - Red (See Applications)
SKU: MCFLA-RZR9-RPrice: $395.00
Get the MOST clearance from your Polaris RZR 900 XP without a lift! High Lifter’s Max Clearance Front Lower Control Arms give you the MOST clearance in the front of your RZR without adding a lift, keeping the driveline angles the same as stock. The result? No added wear and tear on other components – such as your CV joints, bearings and ball joints.
Our Max Clearance Front Lower Control Arms are also available in white. See part number MCFLA-RZR9-W.
The Max Clearance Front Lower Control Arms feature a dual bend design giving you the MOST clearance you can get from the frame to the hub without adding a lift. Our a-arms provide more than 2” of additional clearance where you need it the most. We designed the Control Arm Kit specifically for RZR owners who are concerned about the additional wear and tear on a UTV when adding a standard lift kit. By maintain factory drivelines and positions, there’s no added wear and tear on your RZR’s components – including the CV axle joints.
The a-arms are crafted from 1 1/16” x .120 wall steel DOM tubing – a serious upgrade from factory materials. Each a-arm features additional gussets adding even more strength where you need it most. Additionally, the a-arms can reuse your factory ball joints and bushings.
NOTE: Be sure to check for worn ball joints, bearings, and bushings before installation and replace them if needed. For replacement ball joints, see BJP-2. For replacement bearings, see WBK-25-1628. For replacement bushings, see BK-50-1076.
Proudly made in the USA!
Polaris RZR 900 XP (11-13)
Polaris RZR 900 XP “4” (12-13)
