High Lifter Signature Series Lift Kit for Polaris Ranger 400/500/800/EV Models (See Applications)
Price: $147.95
Options:
Relocate your shock mounts and get the lift need for tighter suspension and larger mud tires! Our Signature Series lift consistently measures truer (and higher) than the competition!
This kit fits Polaris Mid-Size Rangers with front struts only. This does not fit full-size Rangers with front upper and lower control arms with shocks.
NOTE: You must upgrade the front factory CV axles with Outlaw DHT Axles for these models or an Axle Bar Kit.
Polaris Ranger 2” Signature Series Lift Kit
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 2” Signature Series Lift Kit. Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain. Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit. The product? The Signature Series Lift Kit is even easier to install with a bolt-on application that consistently measures truer over competitor products.
The High Lifter 2” Signature Series Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension. Each Lift Kit part is precision cut and zinc plated for durability and reliability in any environment.
2” Signature Series Lift Kit Features:
·         High Lifter logo precision laser cut into each kit
·         Zinc plated
·         Front and rear lift
Tire Fitment:
Polaris Ranger 400 - Up to 28"
Polaris Ranger 800 Mid-Size - Up to 28"
Polaris Ranger EV Electric - Up to 28"
Polaris Ranger 400 (09-14)
Polaris Ranger 500 & Ranger Crew 500 Mid-Size Only (11-13)
Polaris Ranger 800 Mid-Size Only (13-14)
Polaris Ranger EV Electric (10-14)
NOTE: You must upgrade the front factory CV axles with Outlaw DHT Axles for these models or an Axle Bar Kit. High Lifter Pro Series Axles or Gorilla axles are also acceptable upgrades.
Note: 1.5" spacers are required in the rear if you run factory wheels with a lift kit installed.
High Lifter Signature Series Lift Kit for Polaris Ranger 400/500/800/EV Models (See Applications) Reviews
High Lifter Warranties
High Lifter Signature Series Lift Kit for Polaris Ranger 400/500/800/EV Models (See Applications) fits the following vehicle(s):
  • 2010 Polaris Ranger 400 4x4 Midsize
  • 2011 Polaris Ranger 400 4x4 Midsize
  • 2012 Polaris Ranger 400 4x4 Midsize
  • 2013 Polaris Ranger 400 4x4 Midsize
  • 2014 Polaris Ranger 400 4x4 Midsize
  • 2011 Polaris Ranger 500 EFI 4x4 Midsize
  • 2012 Polaris Ranger 500 EFI 4x4 Midsize
  • 2013 Polaris Ranger 500 EFI 4x4 Midsize
  • 2011 Polaris Ranger 500 EFI CREW 4x4 Midsize
  • 2012 Polaris Ranger 500 EFI CREW 4x4 Midsize
  • 2013 Polaris Ranger 500 EFI CREW 4x4 Midsize
  • 2013 Polaris Ranger 800 Midsize
  • 2014 Polaris Ranger 800 Midsize
  • 2012 Polaris Ranger EV
  • 2013 Polaris Ranger EV
  • 2014 Polaris Ranger EV
[All vehicle fits]
