Trailing Arm Kit for Polaris RZR XP 900 (Red)
Price: $549.95
Options:
Don’t let your RZR be a drag on rocky terrain or in those deep ruts! High Lifter’s Max Clearance Series Trailing Arms for the Polaris RZR XP 900 gives you the highest clearance available without a lift so you can conquer any terrain with confidence. Our Max Clearance Trailing Arms keep the driveline angles the same as stock with no added wear and tear on other components.
When ordering this kit, please specify during checkout in the notes the type of RZR XP 900 you have, ie 2-seater, "4", or Walker Evans.
Check out our installation video under the Product Manual tab below!
The Max Clearance Series Trailing Arm Kit is also available in white (#PSTA-RZR9-1). Click here to order yours today!
High Lifter’s research and development team engineered the Max Clearance Series Trailing Arms main bar to run parallel to the frame, greatly increasing the approach angle in front of the rear tires and giving you 4 ½” of added clearance – the MOST available from any after-market trailing arm kit. With the arched design, we’ve eliminated the descent of the bar in front of the rear tires, eliminating the drag and scraping that can be seen in some of the roughest and rockiest terrain. Now, when your RZR climbs out of those deep ruts or over large rocks or logs, your rear tires will easily roll over anything in their path.
Crafted from 1 ½ x ¼” wall steel DOM tubing, the Max Clearance Series Trailing Arms are a super-tough upgrade giving your RZR XP 900 an agile edge against rocks and ruts everywhere. Best of all, the Max Clearance Series Trailing Arms work with High Lifter’s Signature Series lift kit or any lift kit that is bolted on to the top of the shock.
4 ½” added ground clearances in front of the rear tires.
Driveline/suspension angles stay the same as factory.
Powder-coated Polaris red or white.
¾” heim joints rated at 28,000 lbs.
Works with any lift kit bolted to top of shock.
Easy bolt-on kit complete with photo instructions.
One kit replaces both trailing arms.
Polaris RZR XP 900 (11-14)
Polaris RZR XP 900 “4” (12-14)
Trailing Arm Kit for Polaris RZR XP 900 (Red) Reviews
Product Rating: (5.00)   # of Ratings: 4   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-4 of 4
1. Shane on 2/12/2014, said:
Haven't got them yet but you know that old saying all good things come to those that wait They shouldn't be far away now have a great day Shane and Josephine Morgan
2. Loris on 12/24/2013, said:
perfect !
3. garrett on 4/9/2013, said:
Best mod I have done on my 900 XP. Whole new machine going through the rocks and ruts in the East Tennessee mountains. Wouldn't want to go back out on the trail without them. Awesome product!!
4. Brian on 2/7/2013, said:
Easy install, working great, no problems, seems like another quaility part
High Lifter Warranties
Trailing Arm Kit for Polaris RZR XP 900 (Red) fits the following vehicle(s):
  • 2011 Polaris RZR 900
  • 2012 Polaris RZR 900
  • 2013 Polaris RZR 900
  • 2014 Polaris RZR 900
  • 2012 Polaris RZR 900 4
  • 2013 Polaris RZR 900 4
  • 2014 Polaris RZR 900 4
  • 2013 Polaris RZR 900 4 EPS
  • 2013 Polaris RZR 900 EPS
[All vehicle fits]
