Max Clearance Lower Radius Bars for Arctic Cat 1000 Wildcat - Green
Price: $234.95
Options:
A bent rear radius bar on your Arctic Cat 1000 Wildcat will hinder your ground clearance and can quickly lead to getting stuck because you’re hung in a rut or on a rock or a shortened ride. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Max Clearance Lower Radius Bar in green.
Our Max Clearance Lower Radius Bars helped this Wildcat finish in the Baja 1000! Check out the article here!
Want to upgrade your upper and lower radius bars? Check out the Lower Radius Bar's companion with the Upper Radius Bar.
Want your bars in black? Click here to get part number PSRA-A1WC-B.
A bent rear radius bar on your Arctic Cat 1000 Wildcat will hinder your ground clearance and can quickly lead to a broken ride or getting stuck because you’re hung in a rut or on a rock. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Max Clearance Lower Radius Bar powder-coated in Arctic Cat green.
Made from 1 ¼” x 3/16” DOM steel tubing, the Max Clearance Lower Radius Bar is a beefy addition compared to the OEM bars (3/4”) and other competitors (1”). The simple bolt-on kit also features a 5/8” heim joint with a load rated at 17,955 pounds and polyurethane bushings for rugged durability in the deepest ruts and along the rockiest terrain.
When comparing the High Lifter Max Clearance Lower Radius Bar to the competitors, you’ll notice that ours give the MOST ground clearance across the entire bar and the most strength. Something you won’t find anywhere else. High Lifter’s Max Clearance Radius Bar will give you the strength and clearance needed for peace of mind when riding the trails!
The Max Clearance Lower Radius Bars also have an upper companion with the Pro Series Upper Radius Bars. Check them out here.
Product features:
-          Extreme arches for maximum ground clearance
-          Powder-coated Arctic Cat green
-          5/8” heim joint with a load rating of 17,955 pounds
-          Polyurethane bushings
-          Simple bolt-on kit
-          Instructions complete with photos for a quick install
*Please refer to "Fits" tab for applications**
Max Clearance Lower Radius Bars for Arctic Cat 1000 Wildcat - Green Reviews
High Lifter Warranties
Max Clearance Lower Radius Bars for Arctic Cat 1000 Wildcat - Green fits the following vehicle(s):
  • 2012 Arctic Cat Wildcat 1000
  • 2013 Arctic Cat Wildcat 1000
  • 2014 Arctic Cat Wildcat 1000
  • 2013 Arctic Cat Wildcat 1000 4
  • 2014 Arctic Cat Wildcat 1000 4
  • 2014 Arctic Cat Wildcat 1000 4 LTD
  • 2014 Arctic Cat Wildcat 1000 4X
  • 2013 Arctic Cat Wildcat 1000 LTD
  • 2014 Arctic Cat Wildcat 1000 LTD
  • 2013 Arctic Cat Wildcat 1000 X
  • 2014 Arctic Cat Wildcat 1000 X
[All vehicle fits]
