AudioFormz Rockford Fosgate 6.5
AudioFormz Rockford Fosgate 6.5" Marine Speaker Upgrade (1 Pair) for RZR/Ranger/Commander Top with 6.5" Cutouts
SKU: AUDIOFMZ-SU-3
Price: $324.95
Upgrade your speakers on your AudioFormz RZR/Ranger/Commander top with 6.5" cutouts to feature the Rockford Fosgate 6.5" Marine Speakers (1 pair).
The AudioFormz Rockford Fosgate 6.5" Marine Speaker upgrade (1 pair) is a black 6.5” full-range speaker with a 1” bridge mounted tweeter perfect for use in marine watercraft or powersports applications. It features a stainless steel grille and is UV and moisture resistant.
     - True Marine Grade compliance
     - 100% UV stable Centrex® injection molded plastic parts
     - Corrosion resistant gold plated polarized input terminals
     - Injection molded mineral filled polypropylene cone body with UV inhibitors
     - UV and Salt-Fog resistant TPE (Thermo-Plastic Elastomer) surround
     - 1" (25mm) bridge mounted component grade coated aluminum alloy tweeter
     - 18 gauge corrosion resistant removable Stainless Steel grille cover insert
     - Ultra-flexible fully insulated silicone lead wire
     - Spare terminal set for optional additional tweeters
     - Moisture, tear and fatigue resistant aramid fiber spider
     - Linear, high excursion matched motor magnetics and suspension design
     - Integrated 12dB/octave sealed crossover with integrated protection circuit
     - Removable trim ring
