High Lifter Signature Series 5" Adjustable Lift Kit for Polaris 900 RZR XP, 900 RZR XP "4" (11-13)
SKU: PLK900RZR-51Price: $379.95
Redesigned and better than ever! The 5” Lift Kit for the Polaris RZR XP gives you the ground clearance needed for your favorite tires and trails and is adjustable for 2-seater standard cabs so you change back to the stock height location as needed!
Note: The adjustable function does not work with the Polaris 900 RZR XP 4 seater models.
Bigger. Badder. BOLDER. Take your RZR to the edge with High Lifter’s 5” Adjustable Lift Kit. Up your ground clearance and make room for larger tires to dig deep and ride hard in any terrain. Our staff engineers have spent over 15 years perfecting the ultimate lift kit. This is the largest kit available for the RZR XP that maximizes lift while maintaining the stock axles. If you find a bigger kit claiming more ground clearance with stock axles – beware. The product? An easy-to-install, bolt-on lift that consistently measures truer over competitor products.
The High Lifter 5” Lift Kit relocates the shock mounts to provide additional lift, making room for larger tires, tightening suspension, and improving handing. Each piece of the Lift Kit is laser precision-cut from ¼ steel. RZR XP kits are powder coated red to match the Polaris red on the ATV for a clean looking lift that’s durable and reliable in any environment.
The adjustable portion of the kit gives you the option of running your 900 XP standard cab 2-seater in the 5" lifted position for optimal ground clearance or you can change back to the stock height location on the lift brackets for hardcore trail riding without having to remove your lift kit! Additionally, the adjustable kit allows you to install our High Lifter Front Winch Bumper (BUMPER-RZR9) without clearance issues on the bumper brackets! You must rotate the shock reservoir 180 degress for proper installation and clearances. See the lift kit instructions for details on rotating the shock reservoir.
High Lifter's Steering Stops (RANGER-SSK) are a must-have for RZR Lift Kit owners. The Steering Stops helps reduce the turn radius and can help prevent breaking an axle. Click HERE to add a set of Steering Stops to your order today!
High Lifter's Pro Series Arched Radius Bars are another must-have for RZR Lift Kit owners offering a significant increase in ground clearance! Also available are High Lifter's Pro Series Upper Straight Radius Bars - a beefy addition for any driver!
5” Lift Kit Features:
· Kit is adjustable from lifted position to stock position
· User-friendly instructions
· Powder-coated red to match Polaris red
· Precision laser cut from ¼” steel
· Front and rear lift
· Steel name plate
· Engineer designed – High Lifter Rider Tested
Polaris 900 RZR XP 2 seater (11-13)
Polaris 900 RZR XP 4 seater (12-13)
Note: This lift kit will not work on a Walker Evans Edition RZR 900 XP if you are also running the High Lifter or EMP RZR 900 XP bumper.
