Fill 'er Up!
Hunting West Texas, the brush is horrible on tires. Tried a quart in 1 tire to see if it worked, since the tire would need air everyday. Not anymore! Just received my 5 gallons, will fill both buggy’s and all my spare tires. Couldn’t be happier!
