HLP INSTALLED PRO SERIES TIRE SEALANT- (32 oz. of Pro Series sealant installed in customer's tire by High Lifter)
SKU: PSTS-INPrice: $16.95
SELECT QTY OF 1 FOR "EACH" ATV TIRE THAT NEEDS 32oz. OF INSTALLED AIRLOCK.
Have High Lifter's experts install our Pro Series Tire Sealant for you at our headquarters in Shreveport, Louisiana.
Let High Lifter do the work for you by having us install High Lifter's Pro Series Tire Sealant. SELECT QTY OF 1 FOR "EACH" ATV TIRE THAT NEEDS 32oz. OF INSTALLED AIRLOCK.
Fill 'er Up!
32 oz. per tire recommended.
- Will not freeze or harden.
- Will not rust steel or corrode aluminum.
- Will not dry rot in stored ATVs.
- Will not clog valve stems.
- Biodegradable and water-soluable.
Proudly made in the USA!
