SKU: PSTS-32
Price: $16.95
Protect your tires with the industry-leading tire sealant!
  • Seals punctures up to 1/2" in the tread.
  • Seals punctures up to 1/4" in the sidewall.
Fill 'er Up!
32 oz. per tire recommended.
  • Will not freeze or harden.
  • Will not rust steel or corrode aluminum.
  • Will not dry rot in stored ATVs.
  • Will not clog valve stems.
  • Biodegradable and water-soluble.
Proudly made in the USA!
Product Rating: (5.00)   # of Ratings: 2   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-1 of 1
1. Anonymous User on 2/19/2013, said:
I had tried many times to plug a leak in my Polaris Ranger tire but it would always start leaking again. My brother-in-law put a can of Slime in the tire thinking he was helping and that did not work either, just caused a big mess. I called and spoke with Cale, who was more than helpful in selecting the right product and how much I would need. I then ordered the product which arrived very fast. I have had the product in the tire for over a month now with absolutely no leak. I will be filling all my lawn equipment tires as well with this product.
