High Lifter Front & Rear Spring Kit for Can-Am Commander 800/1000 (11-15)
Price:$280.90
Options:
High Lifter Lift Springs are a set of higher capacity replacement springs which are components of the stock shock absorbers. The original equipment spring is not heavy duty and is often fatigued early by heavy loads or continuous service. OEM springs tend to fatigue rapidly…even with low mileage.
The High Lifter Lift Springs were engineered to provide about 100 additional pounds of capacity (per set) over the new stock springs. They were also designed to make a significant difference in the performance of your ATV with as little affect as possible on the ride and handling of the machine. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them.
And here’s a big bonus! A complete set of the Lift Springs may be installed for substantially less than the cost of one replacement OEM shock. For those who ride at slower speeds, with big tires and heavier loads, the Lift Springs will be a welcome and economical upgrade. Depending on the make and model…and current modifications to the unit, the High Lifter Lift Springs have been known to add on full inch of suspension lift…however, it’s not guaranteed. The Lift Springs add some stiffness to the ride and decrease roll, but have not been found harsh or uncomfortable by anyone who has ridden them. One thing is for sure. If you are a hardcore mud rider…or you carry a load…your ATV could stand a heavier load capacity. The High Lifter Lift Springs are just what the doctor ordered!
Commander 800 STD & XT (11-15)
Commander 800 DPS (14-15)
Commander 800 LTD (2014 Only)
Commander 1000 STD (11-14)
Commander 1000 XT (11-15)
Commander 1000 DPS (14-15)
Commander 1000 LTD (2014)
NOTE: DOES NOT fit Commander 1000X model with Fox Shocks, 2015 Commander 1000 LTD & XT-P, or Commander Max Models. The High Lifter Spring tool cannot be used with any RUV application.
NOTE: Powder-coating the springs will void any warranty. If you wish to paint your springs, you must use a different method.
High Lifter Front & Rear Spring Kit for Can-Am Commander 800/1000 (11-15) Reviews
Customer Reviews
(0.00)
# of Ratings: 0
This is a topic called 'returns-short' which you can add via admin and use to show your returns policy.
High Lifter Warranties
High Lifter Front & Rear Spring Kit for Can-Am Commander 800/1000 (11-15) fits the following vehicle(s):
  • 2011 Can-Am Commander 1000
  • 2012 Can-Am Commander 1000
  • 2013 Can-Am Commander 1000
  • 2014 Can-Am Commander 1000
  • 2013 Can-Am Commander 1000 DPS
  • 2014 Can-Am Commander 1000 DPS
  • 2015 Can-Am Commander 1000 DPS
  • 2016 Can-Am Commander 1000 DPS
  • 2017 Can-Am Commander 1000 DPS
  • 2014 Can-Am Commander 1000 LTD
  • 2011 Can-Am Commander 1000 XT
  • 2012 Can-Am Commander 1000 XT
  • 2013 Can-Am Commander 1000 XT
  • 2014 Can-Am Commander 1000 XT
  • 2015 Can-Am Commander 1000 XT
  • 2016 Can-Am Commander 1000 XT
  • 2017 Can-Am Commander 1000 XT
  • 2011 Can-Am Commander 800
  • 2012 Can-Am Commander 800
  • 2013 Can-Am Commander 800
  • 2014 Can-Am Commander 800
  • 2015 Can-Am Commander 800
  • 2013 Can-Am Commander 800 DPS
  • 2014 Can-Am Commander 800 DPS
  • 2015 Can-Am Commander 800 DPS
  • 2016 Can-Am Commander 800 DPS
  • 2017 Can-Am Commander 800 DPS
  • 2012 Can-Am Commander 800 XT
  • 2013 Can-Am Commander 800 XT
  • 2014 Can-Am Commander 800 XT
  • 2015 Can-Am Commander 800 XT
  • 2016 Can-Am Commander 800 XT
  • 2017 Can-Am Commander 800 XT
[All vehicle fits]
