Rear Axle Bar Kit - Polaris RZR 800 (11-13)
Price: $124.95
Options:
The High Lifter Axle Bar Kit is required when installing a lift kit on a Polaris RZR.
Show Picture 1Show Picture 2
The High Lifter Axle Bar Kit replaces OEM axle bars which bind up with a lift kit installed. This kit only replaces the axle bars - riders will reuse factory axle cups and boots. After installation, you can add your Signature Series High Lifter Lift Kit and hit the trails with ease of mind.
This kit includes 2 new OEM grade custom length rear axle bars and 8 new CV boot bands. When installed, this kit allows you to run our lift kit on a Polaris 800 RZR by replacing your factory axle bars which bind up with a lift kit installed. This kit only replaces the axle bars; these are not complete axles.
Polaris 800 RZR (11-13) Does not fit RZR "S" or "4"
Note: A special, heavy duty banding tool is required for installation of the 3/8" wide bands included with this kit. We offer part number
DHT-CVTOOL
, but there are also other tools available in the automotive market. This kit only replaces the axle bars; these are not complete axles. You must reuse your factory axle cups and boots Check your CV joints and all components for wear or damage and to make sure you have the proper amount of grease in the cup before re-installing the bar.
Rear Axle Bar Kit - Polaris RZR 800 (11-13) Reviews
Product Rating: (4.50)   # of Ratings: 2   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-2 of 2
1. Anonymous User on 3/25/2014, said:
Go would recommend .
2. Anonymous User on 3/6/2014, said:
Great preventative damage control . A little work. Goes good on a new machine. The boot clamps leave a little bit to desire
High Lifter Warranties
Rear Axle Bar Kit - Polaris RZR 800 (11-13) fits the following vehicle(s):
  • 2011 Polaris RZR 800
  • 2012 Polaris RZR 800
  • 2013 Polaris RZR 800
  • 2014 Polaris RZR 800
  • 2011 Polaris RZR 800 EPS
[All vehicle fits]
