500 Lumen LED Round Work Light (10-50 Volt) Spot Light Pattern
Show Picture 1Show Picture 2Show Picture 3Show Picture 4Show Picture 5Show Picture 6
SKU: LED-5RO-S
Price: $69.95
Amplify your ride's lighting and hit the trails with the ultra durable 500 Lumen LED Round Work Light! This LED Round Work Light has a spot light illumination pattern. See pictures for more information.
Announcing the 4 inch Round 500 Lumen LED Work Light that is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications. Waterproof o-ring sealed design with a rugged die cast aluminum housing protects from dust, vibration and moisture in the toughest work environments. LED Work Lights carry a 3 Year No Hassle Warranty.
Spot - This pattern casts a focused and concentrated long range beam of light for illuminating work spaces or objects in the distance.
Benefits & Features:
  • 4 inch Round 500 Lumen LED Work Light is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications.
  • A reputation you can count on for quality products - SoundOff is a leading manufacturer of LED safety lighting for law enforcement, bus & truck markets.
  • Rated to last 30,000+ hours - no more broken or burned out bulbs. LED lighting provides years of reliable, low maintainance bright output to illuminate your work areas & equipment.
  • Mounting bracket is made from a stainless steel and can be tilted forward or back 180 degrees to angle the light where you need it.
  • Waterproof o-ring sealed design with a rugged die cast aluminum housing protects the LEDs from dust, vibration and moisture in the toughest work environments.
  • Color temperature: 5700K.
  • 10 - 50 Vdc for worldwide use.
  • 3 Year No Hassle Warranty.
