High Lifter Signature Series 3" Lift Kit for Polaris Ranger 500/700/800 EFI Ranger and 500/800 Ranger Crew IRS (See Notes!)
Price: $141.95
Options:
High Lifter's Pro Series Alignment Kit (PSAK-1) is REQUIRED if you own or are buying PLK800R-50 or ANY brand of Ranger lift kit and have updgraded or are upgrading to the Pro Series Ranger Tie Rod/Rack End Kit. This kit also upgrades from the OEM 10mm bolt to a 1/2" Gr. 8 bolt to match the heavy duty heim joint in our Tie Rod/Rack End Kit. The alignment kit comes with 2 alignment cones and all hardwared required to upgrade both sides of the Ranger.
Note: This product has replaced lift kit PLK700R-01.
Bigger. Badder. BOLDER. Take your ATV to the edge with High Lifter’s 3” Signature Series Lift Kit.  Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain.  Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit.  The product?  An easy-to-install, bolt-on lift that consistently measures truer over competitor products.
The High Lifter 3” Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension.  Each Lift Kit part  is precision cut and zinc plated for durability and reliability in any environment.
This kit contains alignment cones for 10mm bolts for use with factory tie rod/rod ends and OEM bolts If you have upgraded or plan to upgrade to our Pro Series Tie Rod/Rack End kit, see notes below.
3” Lift Kit Features:
 - All hardware needed for successful installation
 - User-friendly instructions
 - Bolt-on application; takes approximately 1-2 hours for install
  -  Zinc plated
 - Front and rear lift
 - Clear-coated High Lifter name plate
High Lifter's Steering Stops (RANGER-SSK) are a must-have for Ranger Lift Kit owners. The Steering Stops helps reduce the turn radius and can help prevent breaking an axle. Click HERE to add a set of Steering Stops to your order today!
Tire Fitment:
Polaris 800 EFI Ranger XP, HD IRS - Up to 28"
Polaris 800 Ranger Crew IRS - Up to 28"
Polaris 500 EFI Ranger (09-10)
Polaris 700 EFI Ranger XP & HD IRS (2009; will not fit 2009 700 Crew)
Polaris 800 EFI Ranger XP, HD IRS (10-13)
Polaris 800 Ranger Crew IRS (10-14)
Notes:
1.5" spacers are recommended, but a MINIMUM of a 1" wheel spacer is required on the front if you are running 12" diameter factory or aftermarket wheels for the wheel to clear the tie rod with the alignment cones installed. If you are running wide tires a 1.5" or wider spacer may be required depending on the width of the tire for tire to shock clearance at full lock steering.
New Rear High Lifter Outlaw DHT Axles, High Lifter Pro Series Axles, or Gorilla CV Axles are recommended for the 2011-2014 Ranger models before installing ANY brand of lift kit. The 2011-2014 model rangers have lighter duty rear axles than previous year models and are more prone to breakage.
High Lifter Signature Series 3" Lift Kit for Polaris Ranger 500/700/800 EFI Ranger and 500/800 Ranger Crew IRS (See Notes!) Reviews
Product Rating: (5.00)   # of Ratings: 5   (Only registered customers can rate)
1 - Terrible
2 - Bad
3 - OK
4 - Good
5 - Great
0% 50% 100%
Showing comments 1-5 of 5
1. Anonymous User on 1/7/2015, said:
everything was great customer was happy
2. Anonymous User on 3/18/2014, said:
Great product Easy to install Great value best lift on the market
3. Anonymous User on 4/23/2013, said:
Awesome service ! one of us made a mistake on my address i called them they were going to ship out new parts overnight so i wouldnt miss my ride ! that is awesome
4. Anonymous User on 3/19/2013, said:
Very easy to install and works great!! Very pleased!!! Thanks
5. Anonymous User on 2/28/2013, said:
The sales personel are very helpful and informative when it come to ordering over the phone with them by email or however you wanna do it i will be ordering more in the near future From them
High Lifter Warranties
High Lifter Signature Series 3" Lift Kit for Polaris Ranger 500/700/800 EFI Ranger and 500/800 Ranger Crew IRS (See Notes!) fits the following vehicle(s):
  • 2009 Polaris Ranger 700 4x4
  • 2009 Polaris Ranger 700 HD EFI 4x4
  • 2010 Polaris  Ranger 800 4x4
  • 2011 Polaris Ranger 800 4x4
  • 2012 Polaris Ranger 800 4x4
  • 2013 Polaris Ranger 800 4x4
  • 2014 Polaris Ranger 800 4x4
  • 2011 Polaris Ranger 800 4x4 EPS
  • 2012 Polaris Ranger 800 4x4 EPS
  • 2010 Polaris Ranger 800 CREW 4x4
  • 2011 Polaris Ranger 800 CREW 4x4
  • 2012 Polaris Ranger 800 CREW 4x4
  • 2013 Polaris Ranger 800 CREW 4x4
  • 2014 Polaris Ranger 800 CREW 4x4
  • 2010 Polaris Ranger 800 HD 4x4
  • 2011 Polaris Ranger 800 HD 4x4
  • 2012 Polaris Ranger 800 HD 4x4
[All vehicle fits]
