| RT40 SPECS/PART NUMBERS |
| Rated Line Pull: 4000 lbs. (1814 kgs) |
| Motor*: 12V DC, 1.5hp (1.1 kW) permanent magnet |
| Controls: Corded remote and mini-rocker control with universal mounting bracket |
| Geartrain: Sealed, all-metal 3-stage planetary |
| Gear Ratio: 136:1 |
| Clutch (freespooling): Sliding pin and ring gear |
| Brake: patented disc brake |
| Drum Diameter/Length: 2.0"/4.7" (52mm/119mm) |
| Fairlead: Roller |
| Rope: 55' Aircraft-grade Wire, 7/32" diameter (16.8m, 5.5 mm diam.) |
| Recommended Battery*: 14 amp/hour minimum |
| Battery Leads: 6 gauge |
| Duty Cyle: Intermittent |
| Warranty: Limited Lifetime (valid in USA and Canada only) |
| Winch Weight: 14.4 lbs. (6.5 kgs) |
| *Designed for use with 12V DC battery systems only. No other voltage systems recommended: |
