WARN XT30 3000# Winch With Synthetic Rope & Wireless Remote
SKU: WARN-76500
Price: $559.95
Description
Riders looking for the most extreme winch on the ATV market will want the XT30. It has a 3,000 lb. line capacity to pull the biggest ATVs; a wireless control system with a 50' range for increased winching options; a short-throw clutch, and 50' of lightweight and easy-to-handle synthetic rope-great for vehicle recovery and plow lifting. Full winch sealing helps keep the elements out, and the all-metal 3-stage planetary geartrain will run smoothly for years. The patented disc brake provides enhanced braking performance, and the efficient electrical system minimizes battery drain.
XT30 SPECS/PART NUMBERS
Rated Line Pull: 3000 lbs (1360 kgs)
Motor*12V DC, .9 hp (.7 kW) permanent magnet, Sealed
Controls: Wireless control system and sealed handlebar-mounted mini-rocker control switch
Geartrain: All-metal 3-stage planetary
Gear Ratio: 154:1
Clutch (freespooling): Sliding pin and ring gear
Brake: patented disc brake
Drum Diameter/Length: 2.0"/2.9" (52mm / 74mm)
Roller: Fairlead
Rope: 50' Synthetic, 3/16" diameter (15 m, 4.76mm diam.)
Recommended Battery*12 Amp/hour minimum
Battery Leads: 6 gauge
Duty Cyle: Intermittent
Warranty: Limited Lifetime (valid in USA and Canada only)
Winch Weight: 13.4 lbs. (6.1 kgs)
*Designed for use with 12V DC battery systems only. No other voltage systems recommended:
PERFORMANCE DATA PULL BY LAYER
Line Pull
Lbs.(Kgs.)
Line Speed
FT./min(M/min.)
Motor
Current
Pull by layer
layer/Lbs(Kgs.)
0 18 (5.5) 14 1/3000 (1360)
1000 (455) 13 (4.0) 67 2/2580 (1170)
2000 (907) 8 (2.4) 125 3/2220 (1007)
3000 (1360) 4 (1.2) 198 4/1910 (866)
