WARN RT30 3000# Winch
SKU: WARN-76000
Price: $424.95
Description
With 3,000 lbs. of pulling power and 50' of durable wire rope, the RT30 is a powerhouse ATV winch. Get-it-done features include an all-metal 3-stage planetary geartrain; full sealing to help keep the elements out; and a patented disc brake for optimum braking performance. With a corded remote, a handlebar-mounted mini-rocker switch and a short-throw clutch, the RT30 provides a great combination of power and control.
RT30 SPECS/PART NUMBERS
Part Number: 81654 (24V)
Rated Line Pull: 3000 lbs (1360 kgs)
Motor*12V DC, .9 hp (.7 kW) permanent magnet, Sealed
Controls: Corded remote and handlebar-mounted mini-rocker control switch
Geartrain: All-metal 3-stage planetary
Gear Ratio: 154:1
Clutch (freespooling): Sliding pin and ring gear
Brake: patented disc brake
Drum Diameter/Length: 2.0"/2.9" (52mm / 74mm)
Fairlead: Roller
Rope: 50' Aircraft-grade Wire, 3/16" diameter (15 m, 5mm diam.)
Recommended Battery*12 Amp/hour minimum
Battery Leads: 6 gauge
Duty Cyle: Intermittent
Warranty: Limited Lifetime (valid in USA and Canada only)
Winch Weight: 15.6 lbs. (7.1 kgs)
*Designed for use with 12V DC battery systems only. No other voltage systems recommended:
PERFORMANCE DATA PULL BY LAYER
Line Pull
Lbs.(Kgs.)
Line Speed
FT./min(M/min.)
Motor
Current
Pull by layer
layer/Lbs(Kgs.)
0 18 (5.5) 14 1/3000 (1360)
1000 (455) 13 (4.0) 67 2/2580 (1170)
2000 (907) 8 (2.4) 125 3/2220 (1007)
3000 (1360) 4 (1.2) 198 4/1910 (866)
