| XT25 SPECS/PART NUMBERS |
| Rated Line Pull: 2500 lbs. (1134 kgs) |
| Motor*: 12V DC, .9 hp (.7 kW) permanent magnet, Sealed |
| Control: Sealed handlebar-mounted mini-rocker switch |
| Geartrain: All-metal 3-stage planetary |
| Gear Ratio: 154:1 |
| Clutch (freespooling): Sliding pin and ring gear |
| Brake: patented disc brake |
| Rope: 50' Synthetic, 3/16" diameter (15 m, 4.76mm diam.) |
| Drum Diameter/Length: 2.0"/2.9" (52mm / 74mm) |
| Fairlead: Roller |
| Recommended Battery*: 12 Amp/hour minimum |
| Battery Leads: 8 gauge |
| Duty Cycle: Intermittent |
| Warranty: Limited Lifetime (valid in USA and Canada only) |
| Winch Weight: 13.4 lbs. (6.1 kgs) |
| *Designed for use with 12V DC battery systems only. No other voltage systems recommended: |
