WHEEL SPACER 1.5"4/137 (One Pair)
SKU: WT4/137-15
Price: $89.95
Description
Spacer Width 1.5"
Applications: Kawasaki spacers 4/137 (1 pair) these spacers will not work on the "IRS" Kawasaki 650i/750i Brute Forces or the Kawasaki Mules, but they do work on the Kawasaki 650 "SRA" Brute Force.
