WHEEL SPACER 1.5" 4/115 (One Pair)
SKU: WT4/115-15
Price: $79.95
Description
Spacer Width: 1.5"
Applications:
Arctic Cat spacers 4/115 (1 pair). For models with wheel studs only.
