Wheel Spacers (One Pair) 2.5 Inch 4/110
  • SKU:  WT4/110-25
  • Category: Wheel Spacers
  • Summary: Move your wheels out and get the room needed for bigger tires and more traction in any terrain with High Lifter's Wide Trac Wheel Spacers! One pair.
  • Weight: 7.000000
  • Length: 7.000000
  • Width: 7.000000
  • Height: 5.000000
  • 172.95 USD$172.95
If you're looking for a wider stance, a safer ride, and the ability to bite through the ruts, you need wheel spacers. Wheel spacers will give you a more aggressive look and increase your stability. If you've recently installed a lift and your suspension drew up which resulted in your width decreasing, wheel spacers may be needed to reposition your wheels back to the factory stance.
There are several major benefits provided by installing wheel spacers:
  1. They extend wheel width for greater stability and increased safety. Riders of tall ATVs will feel much more comfortable on side hills with the wider base.
  1. They provide mud tires a fresh "bite" at the side of ruts instead of the ATV simply driving down the deepest part of the center of the ruts where previous riders have been. So, the problem of getting stuck by being "high centered" is reduced.
  1. They allow the installation of larger, aftermarket tires without rubbing shocks, struts, or exhaust systems.
High Lifter's wheel spacers are machined from aircraft grade 6061 billet aluminum and use grade 8 studs. No OEM studs are required to be removed from the ATV and stud extenders are not used. Wheel spacers bolt to existing studs and the wheel is then bolted to the grade 8 wheel spacer stud furnished. This design is the strongest available to ATVs and are comparable to automotive grade wheel adapters.
Spacer Width: 2.5"
Applications: 2.5" Honda/Yamaha/Kawasaki spacers 4/110 (1 pair). Fits most Honda and Yamaha utility ATVs and also fits the Kawasaki 650i/750i IRS Brute Force. Also fits Bennche models.
2016 Honda Rincon 680 4x4
2016 Honda Rubicon 500 4x4
2016 Honda Rubicon 500 EPS
2016 Honda Rubicon 500 EPS Deluxe
2016 Honda Rubicon 500 DCT
2016 Honda Foreman 500 4x4
2016 Honda Foreman 500 ES 4x4
2016 Honda Rancher 420 2x4
2016 Honda Rancher 420 ES 2x4
2016 Honda Rancher 420 4x4
2016 Honda Rancher 420 ES 4x4
2016 Yamaha Kodiak 700
2016 Yamaha Kodiak 700 EPS
2016 Yamaha Kodiak 700 SE
2016 Yamaha Grizzly 700 4x4
2016 Honda Recon 250
2016 Honda Recon 250 ES
2016 Suzuki King QUad 750 AXi
2016 Suzuki King Quad 500 AXi
2016 Suzuki King Quad 400 ASi
2016 Suzuki King Quad 400 FSi
2016 Honda Pioneer 700
1987 Honda Foreman 350
1987 Yamaha Big Bear 350
2022 Yamaha Kodiak 450 4x4
2022 Yamaha Kodiak 700
2022 Yamaha Kodiak 700 EPS
2022 Yamaha Kodiak 700 SE
2022 Honda Foreman 520 4x4
2022 Honda Rancher 420 2x4
2022 Honda Rancher 420 4x4
2022 Honda Rancher 420 ES 2x4
2022 Honda Rancher 420 ES 4x4
2022 Honda Rincon 680 4x4
2022 Honda Rubicon 520 DCT
2022 Honda Rubicon 520 EPS
2022 CFMOTO CForce 800 XC
2022 CFMOTO CForce 500 EPS
2022 CFMOTO CForce 400
2022 CFMOTO ZForce 800 EX
2022 CFMOTO ZForce 800 Trail
2022 CFMOTO ZForce 500 Trail
2022 CFMOTO UForce 800
2021 CFMOTO UForce 800
2022 Suzuki King Quad 500 AXi
2022 Suzuki King Quad 750 AXi
2014 CFMOTO ZForce 800 EX
2015 CFMOTO ZForce 800 EX
2016 CFMOTO ZForce 800 EX
2015 CFMOTO ZForce 800 EPS
2016 CFMOTO ZForce 800 EPS
2016 CFMOTO ZForce 500
2016 CFMOTO ZForce 500 Trail
2023 Honda Foreman 520 4x4
2023 Honda Rancher 420 2x4
2023 Honda Rancher 420 4x4
2023 Honda Rancher 420 ES 2x4
2023 Honda Rancher 420 ES 4x4
2023 Honda Rincon 680 4x4
2023 Honda Rubicon 520 DCT
2023 Honda Rubicon 520 EPS
2023 Yamaha Grizzly 700 4x4
2023 Yamaha Kodiak 450 4x4
2023 Yamaha Kodiak 700
2023 Yamaha Kodiak 700 EPS
2023 Yamaha Kodiak 700 SE
2021 CFMOTO ZForce 800 EX
2023 CFMOTO CForce 400
2023 CFMOTO CForce 500 EPS
2023 CFMOTO CForce 800 XC
2023 CFMOTO ZForce 800 Trail
2024 Honda Rancher 4x4 EPS
2024 Honda Rubicon 4x4 EPS
2024 Honda Foreman 4x4
2024 Honda Foreman 4x4 EPS
2024 Honda Foreman 4x4 ES EPS
2024 Honda Rancher 4x4 ES
2024 Honda Rancher ES
2023 Honda Recon 250
2023 Honda Recon 250 ES
2024 Honda Rancher
2023 Suzuki King Quad 750 AXi
2023 Suzuki King Quad 500 AXi
2013 CFMOTO CForce 500
2013 CFMOTO CForce 800
2013 CFMOTO UForce 800
2014 CFMOTO CForce 500
2014 CFMOTO CForce 800
2014 CFMOTO UForce 800
2015 CFMOTO CForce 500
2015 CFMOTO UForce 800
2016 CFMOTO CForce 500
2016 CFMOTO CForce 800
2016 CFMOTO ZForce 500 HO
2017 CFMOTO CForce 500 S
2017 CFMOTO UForce 800
2017 CFMOTO ZForce 500 Trail
2017 CFMOTO ZForce 800 EX
2017 CFMOTO ZForce 800 Trail
2018 CFMOTO CForce 500 S
2021 CFMOTO CForce 500 EPS
2020 CFMOTO CForce 800 XC
2024 Honda Recon 250
2024 Honda Recon 250 ES
2024 Yamaha Kodiak 450 4x4
2024 Yamaha Kodiak 700
2024 Yamaha Kodiak 700 EPS
2024 Yamaha Kodiak 700 SE
2023 CFMOTO UForce 800
2016 CFMOTO UForce 800
2016 CFMOTO ZForce 800 Trail
2021 Honda Recon 250
2021 Honda Recon 250 ES
2022 Honda Recon 250 ES
2024 Kawasaki Brute Force 750
2024 Kawasaki Brute Force 300
2024 CFMOTO CForce 800 XC
2024 CFMOTO CForce 600
2024 CFMOTO CForce 400
2024 CFMOTO CForce 500
2024 CFMOTO ZForce 800 Trail
2024 CFMOTO UForce 600
2022 CFMOTO CForce 400 L
2023 CFMOTO CForce 400 L
2024 CFMOTO CForce 400 L
2022 CFMOTO CForce 500 L
2023 CFMOTO CForce 500 L
2024 CFMOTO CForce 500 L
2025 Kawasaki Brute Force 300
2025 Kawasaki Brute Force 450 4x4
2024 Honda Rubicon 700 4x4
2025 Honda Rubicon 4x4 EPS
2025 Honda Foreman 4x4
2025 Honda Foreman 4x4 EPS
2025 Honda Rancher
2025 Honda Rancher 4x4
2025 CFMOTO ZForce 800 Trail
2025 CFMOTO UForce 800 XL
2025 CFMOTO UForce 600
2025 CFMOTO CForce 800 Touring
2025 CFMOTO CForce 600 Touring
2025 CFMOTO CForce 500
2025 CFMOTO CForce 400
2025 Honda Recon 250
2025 Honda Recon 250 ES
2025 Kawasaki Brute Force 750
2026 Kawasaki Brute Force 750
2026 Kawasaki Brute Force 750 EPS
2026 Kawasaki Brute Force 750 EPS LE
2026 Kawasaki Brute Force 750 EPS LE Camo
2025 Honda Rubicon 700 4x4
2026 CFMOTO CForce 400
2026 CFMOTO CForce 500
2026 CFMOTO CForce 600
2026 CFMOTO CForce 600 Touring
2026 CFMOTO CForce 800 Touring
2026 CFMOTO UForce 600
2026 CFMOTO UForce 800 XL
2026 CFMOTO ZForce 800 Trail
2026 Honda Rubicon 700 4x4
2026 Honda Rubicon 4x4 EPS
2026 Honda Rubicon 4x4 Auto DCT EPS Deluxe
2026 Honda Recon 250 ES
2026 Honda Rancher 4x4 Auto DCT IRS EPS
2026 Honda Rancher 4x4 Auto DCT EPS
2026 Honda Rancher
2026 Honda Foreman 4x4 EPS
2027 Kawasaki Brute Force 750
2027 Kawasaki Brute Force 750 EPS
2027 Kawasaki Brute Force 750 SE EPS
2027 Kawasaki Brute Force 750 SE EPS Camo
2011 Honda Rubicon 500 EPS 4x4 Auto
2011 Honda Rubicon 500 4x4 Auto
2011 Honda Rincon 680 4x4
2011 Honda Recon 250 ES 2x4
2011 Honda Recon 250 2x4
2011 Honda Rancher 420 ES 4x4
2011 Honda Rancher 420 ES 2x4
2011 Honda Rancher 420 AT 4x4
2011 Honda Rancher 420 4x4
2011 Honda Rancher 420 2x4
2011 Honda Foreman 500 ES 4x4
2011 Honda Foreman 500 EPS 4x4 MAN
2011 Honda Foreman 500 4X4 MAN
2010 Honda Rincon 680 4x4
2010 Honda Rancher 420 ES 4x4
2010 Honda Rancher 420 ES 2x4
2010 Honda Rancher 420 AT 4x4
2010 Honda Rancher 420 4x4
2010 Honda Rancher 420 2x4
2009 Honda Rubicon 500 EPS 4x4 Auto
2009 Honda Rubicon 500 4x4 Auto
2009 Honda Rincon 680 4x4
2009 Honda Recon 250 ES 2x4
2009 Honda Recon 250 2x4
2009 Honda Rancher 420 ES 4x4
2009 Honda Rancher 420 ES 2x4
2009 Honda Rancher 420 AT 4x4
2009 Honda Rancher 420 4x4
2009 Honda Rancher 420 2x4
2009 Honda Foreman 500 ES EPS 4x4
2009 Honda Foreman 500 ES 4x4
2009 Honda Foreman 500 EPS 4x4 MAN
2009 Honda Foreman 500 4X4 MAN
2009 Honda Big Red 700
2008 Honda Rubicon 500 4x4 Auto
2008 Honda Rincon 680 4x4
2008 Honda Recon 250 ES 2x4
2008 Honda Recon 250 2x4
2008 Honda Rancher 420 ES 4x4
2008 Honda Rancher 420 ES 2x4
2008 Honda Rancher 420 4x4
2008 Honda Rancher 420 2x4
2008 Honda Foreman 500 ES EPS 4x4
2008 Honda Foreman 500 ES 4x4
2008 Honda Foreman 500 EPS 4x4 MAN
2008 Honda Foreman 500 4X4 MAN
2007 Honda Rubicon 500 4x4 Auto
2007 Honda Rincon 680 4x4
2007 Honda Recon 250 ES 2x4
2007 Honda Recon 250 2x4
2007 Honda Rancher 420 ES 4x4
2007 Honda Rancher 420 ES 2x4
2007 Honda Rancher 420 4x4
2007 Honda Rancher 420 2x4
2007 Honda Rancher 400 AT 4x4
2007 Honda Foreman 500 ES EPS 4x4
2007 Honda Foreman 500 ES 4x4
2007 Honda Foreman 500 4X4 MAN
2006 Honda Rubicon 500 4x4 Auto
2006 Honda Rincon 680 4x4
2006 Honda Recon 250 ES 2x4
2006 Honda Recon 250 2x4
2006 Honda Rancher 400 AT 4x4
2006 Honda Rancher 350 S 4x4
2006 Honda Rancher 350 S 2x4
2006 Honda Rancher 350 ES 4x4
2006 Honda Rancher 350 ES 2x4
2006 Honda Foreman 500 ES 4x4
2006 Honda Foreman 500 2x4 MAN
2005 Honda Rubicon 500 4x4 Auto
2005 Honda Rincon 650 4x4
2005 Honda Recon 250 ES 2x4
2005 Honda Recon 250 2x4
2005 Honda Rancher 400 AT 4x4
2005 Honda Rancher 350 S 4x4
2005 Honda Rancher 350 S 2x4
2005 Honda Rancher 350 ES 4x4
2005 Honda Rancher 350 ES 2x4
2005 Honda Foreman 500 ES 4x4
2005 Honda Foreman 500 2x4 MAN
2004 Honda Rincon 650 4x4
2004 Honda Recon 250 ES 2x4
2004 Honda Recon 250 2x4
2004 Honda Rancher 400 AT 4x4
2004 Honda Rancher 350 S 4x4
2004 Honda Rancher 350 S 2x4
2004 Honda Rancher 350 ES 4x4
2004 Honda Rancher 350 ES 2x4
2004 Honda Foreman 450 S 4X4
2004 Honda Foreman 450 ES 4x4
2003 Honda Rincon 650 4x4
2003 Honda Recon 250 ES 2x4
2003 Honda Recon 250 2x4
2003 Honda Rancher 350 S 4x4
2003 Honda Rancher 350 S 2x4
2003 Honda Rancher 350 ES 4x4
2003 Honda Rancher 350 ES 2x4
2003 Honda Foreman 450 S 4X4
2003 Honda Foreman 450 ES 4x4
2003 Honda Foreman 400 4X4
2002 Honda Recon 250 ES 2x4
2002 Honda Recon 250 2x4
2002 Honda Rancher 350 S 4x4
2002 Honda Rancher 350 S 2x4
2002 Honda Rancher 350 ES 4x4
2002 Honda Rancher 350 ES 2x4
2002 Honda Foreman 450 S 4X4
2002 Honda Foreman 450 ES 4x4
2002 Honda Foreman 400 4X4
2001 Honda Recon 250 2x4
2001 Honda Rancher 350 S 4x4
2001 Honda Rancher 350 S 2x4
2001 Honda Rancher 350 ES 4x4
2001 Honda Rancher 350 ES 2x4
2001 Honda Foreman 450 S 4X4
2001 Honda Foreman 450 ES 4x4
2001 Honda Foreman 400 4X4
2000 Honda Recon 250 2x4
2000 Honda Rancher 350 S 4x4
2000 Honda Rancher 350 S 2x4
2000 Honda Rancher 350 ES 4x4
2000 Honda Rancher 350 ES 2x4
2000 Honda Fourtrax 300 4X4
2000 Honda Fourtrax 300 2x4
2000 Honda Foreman 450 S 4X4
2000 Honda Foreman 450 ES 4x4
2000 Honda Foreman 400 4X4
1999 Honda Recon 250 2x4
1999 Honda Fourtrax 300 4X4
1999 Honda Fourtrax 300 2x4
1999 Honda Foreman 450 S 4X4
1999 Honda Foreman 450 ES 4x4
1999 Honda Foreman 400 4X4
1998 Honda Recon 250 2x4
1998 Honda Fourtrax 300 4X4
1998 Honda Foreman 450 S 4X4
1998 Honda Foreman 450 ES 4x4
1998 Honda Foreman 400 4X4
1997 Honda Recon 250 2x4
1997 Honda Fourtrax 300 4X4
1997 Honda Foreman 400 4X4
1996 Honda Fourtrax 300 4X4
1996 Honda Foreman 400 4X4
1995 Honda Fourtrax 300 4X4
1995 Honda Foreman 400 4X4
2011 Suzuki King Quad 750 AXi
2011 Suzuki King Quad 500 AXi
2011 Suzuki King Quad 450 AXi
2010 Suzuki King Quad 450 AXi
2010 Suzuki King Quad 400 FS
2010 Suzuki King Quad 400 AS
2009 Suzuki King Quad 750 AXi
2009 Suzuki King Quad 450 AXi
2009 Suzuki King Quad 400 FS
2009 Suzuki King Quad 400 AS
2008 Suzuki King Quad 750 AXi
2008 Suzuki King Quad 450 AXi
2008 Suzuki King Quad 400 FS
2008 Suzuki King Quad 400 AS
2007 Suzuki Vinson 500 4x4 MAN
2007 Suzuki Vinson 500 4x4 AUTO
2007 Suzuki King Quad 700 4x4
2007 Suzuki King Quad 450 AXi
2007 Suzuki Eiger 400 4x4 MAN
2006 Suzuki Vinson 500 4x4 MAN
2006 Suzuki Vinson 500 4x4 AUTO
2006 Suzuki King Quad 700 4x4
2006 Suzuki Eiger 400 4x4 MAN
2005 Suzuki Vinson 500 4x4 MAN
2005 Suzuki Vinson 500 4x4 AUTO
2005 Suzuki Eiger 400 4x4 MAN
2004 Suzuki Vinson 500 4x4 MAN
2004 Suzuki Vinson 500 4x4 AUTO
2004 Suzuki Eiger 400 4x4 MAN
2004 Suzuki Eiger 400 2x4 MAN
2003 Suzuki Vinson 500 4x4 AUTO
2003 Suzuki Eiger 400 4x4 MAN
2003 Suzuki Eiger 400 2x4 MAN
2002 Suzuki Vinson 500 4x4 AUTO
2002 Suzuki King Quad 300 4x4
2002 Suzuki Eiger 400 4x4 MAN
2002 Suzuki Eiger 400 2x4 MAN
2001 Suzuki King Quad 300 4x4
2000 Suzuki King Quad 300 4x4
1999 Suzuki King Quad 300 4x4
1998 Suzuki King Quad 300 4x4
2011 Yamaha Rhino 700 4x4
2011 Yamaha Grizzly 700 4x4
2011 Yamaha Grizzly 550 4x4
2011 Yamaha Grizzly 450 4x4
2010 Yamaha Wolverine 450 4x4
2010 Yamaha Grizzly 700 4x4
2010 Yamaha Grizzly 450 4x4
2010 Yamaha Grizzly 350 4x4
2010 Yamaha Grizzly 350 2x4
2010 Yamaha Big Bear 400 4x4
2009 Yamaha Wolverine 450 4x4
2009 Yamaha Wolverine 350 2x4
2009 Yamaha Rhino 700 4x4
2009 Yamaha Rhino 450 4x4
2009 Yamaha Grizzly 700 4x4
2009 Yamaha Grizzly 550 4x4
2009 Yamaha Grizzly 450 4x4
2009 Yamaha Grizzly 350 4x4
2009 Yamaha Grizzly 350 2x4
2009 Yamaha Grizzly 125
2009 Yamaha Big Bear 400 4x4
2009 Yamaha Big Bear 250 2x4
2008 Yamaha Wolverine 450 4x4
2008 Yamaha Wolverine 350 2x4
2008 Yamaha Rhino 450 4x4
2008 Yamaha Grizzly 700 4x4
2008 Yamaha Grizzly 660 4x4
2008 Yamaha Grizzly 450 4x4
2008 Yamaha Grizzly 350 4x4
2008 Yamaha Grizzly 350 2x4
2008 Yamaha Grizzly 125
2008 Yamaha Big Bear 400 4x4
2008 Yamaha Big Bear 250 2x4
2007 Yamaha Wolverine 450 4x4
2007 Yamaha Wolverine 350 4x4
2007 Yamaha Rhino 660 4x4
2007 Yamaha Rhino 450 4x4
2007 Yamaha Grizzly 700 4x4
2007 Yamaha Grizzly 660 4x4
2007 Yamaha Grizzly 450 4x4
2007 Yamaha Grizzly 400 4x4
2007 Yamaha Grizzly 350 4x4
2007 Yamaha Grizzly 350 2x4
2007 Yamaha Grizzly 125
2007 Yamaha Big Bear 250 2x4
2006 Yamaha Wolverine 450 4x4
2006 Yamaha Wolverine 350 4x4
2006 Yamaha Rhino 660 4x4
2006 Yamaha Kodiak 450 4x4
2006 Yamaha Kodiak 400 4x4
2006 Yamaha Grizzly 660 4x4
2006 Yamaha Grizzly 125
2006 Yamaha Bruin 350 4x4
2006 Yamaha Bruin 350 2x4
2006 Yamaha Big Bear 400 4x4
2005 Yamaha Wolverine 350 4x4
2005 Yamaha Rhino 660 4x4
2005 Yamaha Kodiak 450 4x4
2005 Yamaha Kodiak 400 4x4
2005 Yamaha Grizzly 660 4x4
2005 Yamaha Grizzly 125
2005 Yamaha Bruin 350 4x4
2005 Yamaha Bruin 350 2x4
2005 Yamaha Big Bear 400 4x4
2004 Yamaha Wolverine 350 4x4
2004 Yamaha Rhino 660 4x4
2004 Yamaha Kodiak 450 4x4
2004 Yamaha Kodiak 400 4x4
2004 Yamaha Kodiak 400 2x4
2004 Yamaha Grizzly 660 4x4
2004 Yamaha Grizzly 125
2004 Yamaha Bruin 350 4x4
2004 Yamaha Bruin 350 2x4
2004 Yamaha Big Bear 400 4x4
2004 Yamaha Big Bear 400 2x4
2003 Yamaha Wolverine 350 4x4
2003 Yamaha Kodiak 450 4x4
2003 Yamaha Kodiak 400 4x4
2003 Yamaha Kodiak 400 2x4
2003 Yamaha Grizzly 660 4x4
2003 Yamaha Big Bear 400 4x4
2003 Yamaha Big Bear 400 2x4
2002 Yamaha Wolverine 350 4x4
2002 Yamaha Kodiak 400 4x4
2002 Yamaha Grizzly 660 4x4
2002 Yamaha Big Bear 400 4x4
2002 Yamaha Big Bear 400 2x4
2001 Yamaha Wolverine 350 4x4
2001 Yamaha Kodiak 400 4x4
2001 Yamaha Kodiak 400 2x4
2001 Yamaha Grizzly 600 4x4
2001 Yamaha Big Bear 400 4x4
2001 Yamaha Big Bear 400 2x4
2000 Yamaha Wolverine 350 4x4
2000 Yamaha Kodiak 400 4x4
2000 Yamaha Kodiak 400 2x4
2000 Yamaha Grizzly 600 4x4
2000 Yamaha Big Bear 400 4x4
1999 Yamaha Wolverine 350 4x4
1999 Yamaha Kodiak 400 4x4
1999 Yamaha Grizzly 600 4x4
1999 Yamaha Big Bear 350 4x4
1999 Yamaha Big Bear 350 2x4
1998 Yamaha Wolverine 350 4x4
1998 Yamaha Kodiak 400 4x4
1998 Yamaha Grizzly 600 4x4
1998 Yamaha Big Bear 350 4x4
1998 Yamaha Big Bear 350 2x4
1997 Yamaha Wolverine 350 4x4
1997 Yamaha Kodiak 400 4x4
1997 Yamaha Big Bear 350 4x4
1997 Yamaha Big Bear 350 2x4
1996 Yamaha Wolverine 350 4x4
1996 Yamaha Kodiak 400 4x4
1996 Yamaha Big Bear 350 4x4
1996 Yamaha Big Bear 350 2x4
1995 Yamaha Big Bear 350 4x4
1995 Yamaha Kodiak 400 4x4
2005 Suzuki King Quad 700 4x4
2008 Yamaha Rhino 700 4x4
1991 Honda Fourtrax 200
1992 Honda Fourtrax 200
1993 Honda Fourtrax 200
1994 Honda Fourtrax 200
1995 Honda Fourtrax 200
1996 Honda Fourtrax 200
1997 Honda Fourtrax 200
1988 Honda Fourtrax 300
1989 Honda Fourtrax 300
1990 Honda Fourtrax 300
1991 Honda Fourtrax 300
1992 Honda Fourtrax 300
1993 Honda Fourtrax 300
1994 Honda Fourtrax 300
1994 Yamaha Wolverine 350 4x4
1995 Yamaha Wolverine 350 4x4
2004 Yamaha Pro Hauler 700
2005 Yamaha Pro Hauler 700
2006 Yamaha Pro Hauler 700
2004 Yamaha Pro Hauler 1000
2005 Yamaha Pro Hauler 1000
2011 Suzuki King Quad 400 AS
2011 Suzuki King Quad 400 FS
2010 Yamaha Grizzly 125
2011 Yamaha Grizzly 125
2011 Yamaha Grizzly 350 2x4
2011 Yamaha Grizzly 350 4x4
2011 Yamaha Wolverine 450 4x4
2010 Bennche Spire 800
2011 Bennche Spire 800
2009 Bennche Big Horn 700
2010 Bennche Big Horn 700
2011 Bennche Big Horn 700
2010 Bennche Gray Wolf 700
2011 Bennche Gray Wolf 700
2012 Suzuki King Quad 750 AXi
2012 Suzuki King Quad 500 AXi
2012 Honda Rincon 680 4x4
2012 Honda Rubicon 500 EPS 4x4 Auto
2012 Honda Rubicon 500 4x4 Auto
2012 Honda Foreman 500 ES 4x4
2012 Honda Foreman 500 EPS 4x4 MAN
2012 Honda Foreman 500 ES EPS 4x4
2012 Honda Rancher 420 2x4
2012 Honda Rancher 420 ES 2x4
2012 Honda Rancher 420 4x4
2012 Honda Rancher 420 ES 4x4
2012 Honda Rancher 420 AT 4x4
2012 Honda Recon 250 2x4
2012 Honda Recon 250 ES 2x4
2012 Yamaha Grizzly 700 4x4
2012 Yamaha Grizzly 550 4x4
2012 Yamaha Grizzly 450 4x4
2012 Yamaha Big Bear 400 4x4
2012 Yamaha Grizzly 350 4x4
2012 Yamaha Grizzly 125
2012 Yamaha Rhino 700 4x4
2012 Suzuki King Quad 400 AS
2012 Suzuki King Quad 400 FS
2013 Suzuki King Quad 750 AXi
2013 Suzuki King Quad 500 AXi
2013 Suzuki King Quad 400 AS
2013 Suzuki King Quad 400 FS
2013 Honda Rincon 680 4x4
2013 Honda Rubicon 500 4x4 Auto
2013 Honda Rubicon 500 EPS 4x4 Auto
2013 Honda Foreman 500 ES 4x4
2013 Honda Foreman 500 EPS 4x4 MAN
2013 Honda Foreman 500 ES EPS 4x4
2013 Honda Rancher 420 2x4
2013 Honda Rancher 420 ES 2x4
2013 Honda Rancher 420 4x4
2013 Honda Rancher 420 ES 4x4
2013 Honda Rancher 420 AT 4x4
2013 Honda Recon 250 2x4
2013 Honda Recon 250 ES 2x4
2012 Yamaha Grizzly 300
2013 Yamaha Grizzly 700 4x4
2013 Yamaha Grizzly 550 4x4
2013 Yamaha Grizzly 450 4x4
2013 Yamaha Grizzly 300
2013 Yamaha Grizzly 125
2013 Yamaha Rhino 700 4x4
2010 Honda Big Red 700
2011 Honda Big Red 700
2012 Honda Big Red 700
2014 Yamaha Grizzly 350
2014 Yamaha Grizzly 450 EPS
2014 Yamaha Grizzly 450 4x4
2014 Yamaha Grizzly 700 4x4
2014 Yamaha Grizzly 550 4x4
2014 Honda Recon 250 2x4
2014 Honda Recon 250 ES 2x4
2014 Honda Rubicon 500 4x4
2014 Honda Rubicon 500 Power Steering
2014 Honda Rincon 680 4x4
2014 Honda Rancher 420 AT 4x4
2014 Suzuki King Quad 750 AXi
2014 Suzuki King Quad 500 AXi
2014 Suzuki King Quad 400 ASi
2014 Suzuki King Quad 400 FSi
2014 Honda Rancher 420 2x4
2014 Honda Rancher 420 4x4
2014 Honda Rancher 420 ES 2x4
2014 Honda Rancher 420 ES 4x4
2014 Honda Rancher 420 4x4 PS
2014 Honda Foreman 500 4x4
2014 Honda Foreman 500 ES 4x4
2014 Honda Foreman 500 4x4 PS
1986 Honda Foreman 350
1988 Honda Foreman 350
1989 Honda Foreman 350
1985 Yamaha Big Bear 350
1986 Yamaha Big Bear 350
1988 Yamaha Big Bear 350
1989 Yamaha Big Bear 350
1990 Yamaha Big Bear 350
1991 Yamaha Big Bear 350
1992 Yamaha Big Bear 350
1993 Yamaha Big Bear 350
1994 Yamaha Big Bear 350
2011 Yamaha Big Bear 400 4x4
2015 Suzuki King Quad 750 AXi
2015 Suzuki King Quad 400 ASi
2015 Suzuki King Quad 400 FSi
2015 Honda Rincon 680 4x4
2015 Honda Rubicon 500 4x4
2015 Honda Rubicon 500 EPS
2015 Honda Rubicon 500 EPS Deluxe
2015 Honda Rubicon 500 DCT
2015 Honda Rubicon 500 DCT EPS
2015 Honda Foreman 500 4x4
2015 Honda Foreman 500 ES 4x4
2015 Honda Rancher 420 2x4
2015 Honda Rancher 420 ES 2x4
2015 Honda Rancher 420 4x4
2015 Honda Rancher 420 ES 4x4
2015 Yamaha Grizzly 700 4x4
2015 Honda Recon 250
2017 Honda Rincon 680 4x4
2017 Honda Rancher 420 2x4
2017 Honda Rancher 420 4x4
2017 Honda Rancher 420 ES 4x4
2017 Honda Recon 250
2017 Honda Recon 250 ES
2017 Yamaha Kodiak 700
2017 Yamaha Kodiak 700 EPS
2017 Yamaha Kodiak 700 SE
2017 Yamaha Grizzly 700 4x4
2017 Suzuki King Quad 750 AXi
2017 Suzuki King Quad 500 AXi
2017 Suzuki King Quad 400 ASi
2017 Suzuki King Quad 400 FSi
2017 Honda Rubicon 500 EPS
2017 Honda Rubicon 500 DCT
2017 Honda Foreman 500 4x4
2018 Yamaha Kodiak 450 4x4
2018 Yamaha Kodiak 700
2018 Yamaha Kodiak 700 EPS
2018 Yamaha Kodiak 700 SE
2018 Yamaha Grizzly 700 4x4
2018 Honda Rincon 680 4x4
2018 Honda Recon 250
2018 Honda Recon 250 ES
2018 Honda Rubicon 500 EPS
2018 Honda Rubicon 500 DCT
2017 CFMOTO CForce 800 EPS
2017 CFMOTO CForce 500 HO EPS
2017 CFMOTO CForce 500 S EPS
2017 CFMOTO CForce 400
2017 CFMOTO ZForce 800 EX EPS
2017 CFMOTO UForce 800 EPS
2017 CFMOTO UForce 500 HO EPS
2018 CFMOTO CForce 800 EPS
2016 CFMOTO CForce 800 EPS
2015 CFMOTO CForce 800 EPS
2018 CFMOTO CForce 500 HO EPS
2016 CFMOTO CForce 500 HO EPS
2015 CFMOTO CForce 500 HO EPS
2014 CFMOTO CForce 500 HO EPS
2018 CFMOTO CForce 500 S EPS
2016 CFMOTO CForce 500 S EPS
2015 CFMOTO CForce 500 S EPS
2018 CFMOTO CForce 400
2016 CFMOTO CForce 400
2018 CFMOTO ZForce 800 EX EPS
2016 CFMOTO ZForce 800 EX EPS
2015 CFMOTO ZForce 800 EX EPS
2014 CFMOTO ZForce 800 EX EPS
2018 CFMOTO UForce 800 EPS
2016 CFMOTO UForce 800 EPS
2015 CFMOTO UForce 800 EPS
2018 CFMOTO UForce 500 HO EPS
2016 CFMOTO UForce 500 HO EPS
2015 CFMOTO UForce 500 HO EPS
2018 Honda Rancher 420 2x4
2018 Honda Rancher 420 4x4
2018 Honda Rancher 420 ES 4x4
2018 Honda Foreman 500 4x4
2018 Suzuki King Quad 750 AXi
2018 Suzuki King Quad 500 AXi
2018 Suzuki King Quad 400 ASi
2018 Suzuki King Quad 400 FSi
2019 Suzuki King Quad 750 AXi
2019 Suzuki King Quad 500 AXi
2019 Suzuki King Quad 400 ASi
2019 Suzuki King Quad 400 FSi
2019 Yamaha Grizzly 700 4x4
2019 Yamaha Kodiak 450 4x4
2019 Yamaha Kodiak 700
2019 Yamaha Kodiak 700 EPS
2019 Yamaha Kodiak 700 SE
2019 Honda Rincon 680 4x4
2019 Honda Recon 250
2019 Honda Recon 250 ES
2019 Honda Rancher 420 2x4
2019 Honda Rancher 420 4x4
2019 Honda Rancher 420 ES 4x4
2019 Honda Foreman 500 4x4
2019 Honda Rubicon 500 EPS
2019 Honda Rubicon 500 DCT
2020 Suzuki King Quad 750 AXi
2020 Suzuki King Quad 500 AXi
2020 Suzuki King Quad 400 ASi
2020 Suzuki King Quad 400 FSi
2020 Yamaha Kodiak 450 4x4
2020 Yamaha Kodiak 700
2020 Yamaha Kodiak 700 EPS
2020 Yamaha Kodiak 700 SE
2020 Honda Rincon 680 4x4
2020 Honda Recon 250
2020 Honda Recon 250 ES
2020 Honda Rancher 420 2x4
2020 Honda Rancher 420 ES 2x4
2020 Honda Rancher 420 4x4
2020 Honda Rancher 420 ES 4x4
2020 Honda Foreman 520 4x4
2020 Honda Rubicon 520 EPS
2020 Honda Rubicon 520 DCT
2021 Honda Rincon 680 4x4
2021 Honda Rancher 420 2x4
2021 Honda Rancher 420 ES 2x4
2021 Honda Rancher 420 4x4
2021 Honda Rancher 420 ES 4x4
2021 Honda Foreman 520 4x4
2021 Honda Rubicon 520 EPS
2021 Honda Rubicon 520 DCT
2021 Suzuki King Quad 750 AXi
2021 Suzuki King Quad 500 AXi
2021 Yamaha Kodiak 450 4x4
2021 Yamaha Kodiak 700
2021 Yamaha Kodiak 700 EPS
2021 Yamaha Kodiak 700 SE
2018 CFMOTO ZForce 500 Trail
2018 CFMOTO ZForce 800 Trail
2018 CFMOTO CForce 500S
2018 CFMOTO CForce 800 XC
2019 CFMOTO UForce 500
2019 CFMOTO UForce 800
2019 CFMOTO ZForce 500 Trail
2019 CFMOTO ZForce 800 EX
2019 CFMOTO ZForce 800 Trail
2019 CFMOTO CForce 400
2019 CFMOTO CForce 500S
2019 CFMOTO CForce 800 XC
2020 CFMOTO UForce 500
2020 CFMOTO UForce 800
2020 CFMOTO ZForce 500 Trail
2020 CFMOTO ZForce 800 Trail
2020 CFMOTO ZForce 800 EX
2020 CFMOTO CForce 400
2020 CFMOTO CForce 500 EPS
2021 CFMOTO CForce 400
2021 CFMOTO CForce 800 XC
2021 CFMOTO ZForce 500 Trail
2021 CFMOTO ZForce 800 Trail
5.0 out of 5 stars
  • Wednesday, December 29, 2021
  • Kyle
The machining seemed high quality. It does what I need it to do.
  • Sunday, March 31, 2019
  • Jason Leonard
Very good and dependable product. Would definitely recommend these spacers
  • Wednesday, October 30, 2013
The wheel spacers did exactly what I was expecting. I went four wheeling two days after putting them on and they were awesome.
