HONDA FOURTRAX 300 (92-01) CAM 2X4 & 4X4 (40 B GRIND)
Price:$161.00
Part#: CAMH300
Unleash the beast in your ATV! Get more power and performance out of your Quad without sacrificing power elsewhere. This camshaft has strong mid range and top end power and is recommended for use with a high compression piston such as those included in our Big Bore kits.
NOTES: MUST HAVE VALVE SPRING KIT (VSH300) Valve Lift: .384 Duration: 272°
APPLICATIONS: HONDA FOURTRAX 300 (92-01)
THERE WILL BE A CAM CORE CHARGE IN THE AMOUNT OF $60.00 ADDED TO YOUR ORDER.
HONDA FOURTRAX 300 (92-01) CAM 2X4 & 4X4 (40 B GRIND) Reviews
Customer Reviews
(0.00)
# of Ratings: 0
This is a topic called 'returns-short' which you can add via admin and use to show your returns policy.
