Cometic top end engine gasket kits are the perfect choice when servicing your atv requires new replacement gaskets. Remember, when you remove a component that is protected by a gasket you must replace the gasket with a new one in order to continue to provide that protection and avoid permanent and/or costly damage to your machine. Cometic design engineers have the ability to analyze the environment the gasket will perform in, select the proper material, and apply the appropriate technology to offer the highest performing gaskets available on the market. The individual gaskets in these kits are all made from the highest-quality materials available, and the contents of each are tailored to the specific needs of the individual engine.
APPLICATIONS: Honda 450 Foreman
