FLOORBOARD KIT- SUZUKI 700 KING QUAD 2005-2007 ONLY
SKU: FKITS700KQ
Price: $69.95
Description
Want to modify your ATV with over-sized tires but concerned about clearance issues between large front tires and factory fender support brackets? Use the High Lifter Fender Kit to move fender support from under the wheel well and provide the additional clearance you need to turn your ATV into the monster you’ve always wanted! The High Lifter Fender kit includes heavy-duty replacement brackets for fender support rods to allow for over-sized tires. The brackets are zinc plated for rust resistance, do not reduce ground clearance, or hang on obstacles. No drilling, cutting, or permanent modification is required for installation. No disassembly of floorboards or body plastic is required. Applications SUZUKI 700 KING QUAD (05)
