Increased power and fuel efficiency! That’s what we’re all looking for. A DynoJet Jet Kit can take care of the problem. Looking for an inexpensive mod that can make a big difference? A jet kit will increase your power and smoothness throughout the entire power-band. At the same time, a jet kit will keep your engine running at the right fuel-air mixture so that you receive the most benefit and optimum fuel efficiency. A DynoJet Jet Kit includes comprehensive instructions which show step-by-step installation and testing procedures to ensure a perfect setup every time. DynoJet and High Lifter work together to develop jet kits for new applications…and jet kits are available for most makes and models. In many cases, there are several jet kits and main jets to fit specific needs and carburetion problems. HELPFUL TIP: If you’ve recently installed snorkels…and something just isn’t quite right? You’ll want to look at the jetting of your machine to see if a minor change could help you out!
APPLICATIONS:
Arctic Cat 300 4x4 (01-05)
