HMF Dobeck Gen 3 EFI Programmer for Honda Rincon 680 (06-14)
Price:$255.00
Options:
HMF makes EFI easy with an Optimizer EFI tuner. Simply plug into the stock injector wire harness, make a ground connection, and you’re ready to go.
This unit electronically 're-maps' fuel injection to deliver optimum performance. Adjustments for changing the conditions are easy – simply use the menu to adjust + or – and use the lights for a particular throttle range.
With an HMF exhaust system and the Optimizer you can increase horsepower significantly over stock, and if you add a free flowing air filter or modify the airbox lid you will get even more horsepower! For this application HMF suggests you install the Optimizer with one of their exhaust systems to maintain the proper air fuel ratio. The Optimizer will prevent higher than normal internal exhaust temperatures.
HMF Dobeck Gen 3 EFI Programmer for Honda Rincon 680 (06-14) Reviews
Customer Reviews
(0.00)
# of Ratings: 0
HMF Dobeck Gen 3 EFI Programmer for Honda Rincon 680 (06-14) fits the following vehicle(s):
  • 2014 Honda Rincon 680
  • 2006 Honda Rincon 680 4x4
  • 2007 Honda Rincon 680 4x4
  • 2008 Honda Rincon 680 4x4
  • 2009 Honda Rincon 680 4x4
  • 2010 Honda Rincon 680 4x4
  • 2011 Honda Rincon 680 4x4
  • 2012 Honda Rincon 680 4x4
  • 2013 Honda Rincon 680 4x4
[All vehicle fits]
