No products found
Try adjusting your filters.
Products couldn't load.
Your stock ATV or UTV clutch can handle quite a bit, including some challenging terrain. But whether you like trail riding, dunes, rock crawling or stick strictly to hard work, chances are you've had at least a few instances where you've had to back away from an obstacle or find a different route because your rig didn't have the top-end capabilities the situation required. That's where we come in. High Lifter has a wide selection of clutch kits designed to drastically improve the performance of your ATV or UTV so you never need to think twice about the next obstacle ahead. Shop our selection below to find the perfect kit to push your machine to the next level!
Kits for all situations
High Lifter has clutch kits tailored for wherever you like to ride your ATV or UTV. Run bigger tires and boost your torque for mud riding, reach and hold high RPMs for the dunes, improve your low-end response while rock crawling or give your machine an all-around boost with a sport utility kit.
Because our kits are customized to your machine's performance requirements, you'll receive a variety of the following components when you order:
- Primary clutch spring
- Secondary clutch spring
- Wet clutch spring
- Custom angle helix
- Roller weights
- Roller weight housings
- Flyweights
- Primary clutch spacer
