zzzt, zzzt, zzzt....
All Forums >> [OEM Discussions] >> Arctic Cat >> zzzt, zzzt, zzzt.... Page: [1]
zzzt, zzzt, zzzt.... - 11/12/2008 7:18:32 AM
tc
that is the sound that my 4x4 actuator is making when i drive through some water. i have sealed up the actuator box and dieelectric greased the connection coming out of the black box. is there something i am missing or do i need to redo my work lol...   and it seems that it is very hard to steer like it kicks in and out of 4x4 at times when it is doing this....
RE: zzzt, zzzt, zzzt.... - 11/12/2008 7:33:09 AM
BuLLg0d
You need to seal your front cover on the actuator and put some dielectric grease on the electrical connection. Its getting water inside of it.
08 ARCTIC CAT 700H-1
09 Thundercat TRV
TEAM STEEL HORSES
POWERED BY ARCTIC CAT
Tuned by Pit Proven Performance
Moto Sport Alloy
CATVOS
Gorilla Axles
Speed Werx
(in reply to tc)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 7:40:00 AM
8upwithmud
Is the switch on your handlebars shorted out or dirty.  The boot is torn on mine.  From time to time, I have to take it apart to clean it.
05 Evil Twin
Bored, stroked, camed, ported, polished,
piped, jetted, snorkeled, clutched, geared,
dynateked, Gorrilla'd, lifted, and lawed.
13 axles
6 motors
6 differentials
1 fan
? belts
04 500M with 28 laws
05 400A with 27 lites
06 Night Rod
http://myspace.com/leebo1973
........................HPAC.........................
.............Hard Pack Arctic Cats.............
(in reply to BuLLg0d)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 8:29:44 AM
also check the plug at the end of the wires closer to the steering stem, put dielectirc grease in it as well.
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
(in reply to 8upwithmud)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 8:44:47 AM
700Blaze
From: Washington MO. home of B&J CUSTOM FABRICATION
Hope its just a connection
"700 CAT"
FULLY CUSTOM BUILT BY
MY SPACE-----MY PHOTOS
THE BOYS OFFROAD CLUB
(in reply to GWC)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 8:55:25 AM
tc
ok thanks i will check it all. if it is the actuator i will just take it in ( i still have warranty) i just dont like being without it my quad.....
(in reply to 700Blaze)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 9:02:35 AM
8upwithmud
That's why when I buy my next bike, it will only have the 6 month warranty.  After that, I will do it all myself.  If not before.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to tc)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 9:07:13 AM
yeap fix my own stuff
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
RE: zzzt, zzzt, zzzt.... - 11/12/2008 6:43:01 PM
redneck36049
check the wire that plugs into the side of the diff. up-under the cable that puts it in diff lock.
2007 ARCTIC CAT 650 H1 - in rehab for a mud addiction
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
SOON TO COME: CANT SAY BUT IT WILL BE BAD
WANT A CAT CALL STEEL HORSES WISH I DID
MY PICS http://www.myspace.com/redneck36049
(in reply to GWC)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 6:56:16 PM
TBONESGRIZZ
ORIGINAL: redneck36049
Got money saying this is the problem... Why you might ask? Cause mine was doing the exact same thing! ha  It is a ground plug and the ground is being shut on/off so to speak.  Mine was clogged with mud and you could touch your fingertip to the metal and it would ground thru you.  Clean it out good, die electric grease the heck out of it and bet it will work fine
'08 Polaris RZR - Project MonstR'
'08 Arctic Cat 700H1
'05 AMR Brute Force 650 SRA
TEAM THROWED OFF ROAD
www.myspace.com/msboyzridindirty
Driven By:
M.O.R.A
(in reply to redneck36049)
RE: zzzt, zzzt, zzzt.... - 11/12/2008 7:09:11 PM
redneck36049
mine done it and i just put it in water up to the diff and i could stick that wire in the water and it did it and pick it up and would go back..... i adjusted the metal round connector (bend it in a lil) in the inside it. put some die-electric grease in it. plug it up and i put some silcone around the edge of it to help it seal up.
all it does is tells your 4wd when the diff lock is engaged. so when it grounds out it will put your bike back in 4wd thinkin that the diff. lock is enaged.
all i do when i get out of the sticky spot i disengage the diff lock and 4wd and pull fwd a few ft and back up a few ft to make sure it is not engaged any more... then after a lil bit down the trail i will spin the back tires just to make sure it is in 2wd...
i hope this helps u
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
(in reply to TBONESGRIZZ)
