wiring my cabin for a generator
All Forums >> [Most Popular Discussions] >> The MUD Hole >> wiring my cabin for a generator Page: [1]
wiring my cabin for a generator - 11/18/2008 12:38:34 PM
AUgrizzrider
Alright need some electrical expertise... I'm in the process of building a new cabin out on my land and need some electrical advice. The cabin will not have commercial power because of its location so I want to wire it up for generator only power. The generator is going to be anywhere from a 5k watt to a 6250 and will only run lights, small water pump, small kitchen appliances and occasionally a small 110 a/c window unit.
What do I need inorder to do this? The generator will sit in a remote spot and when I crank it - I want to be able to flip a breaker and it be ready. I dont want to have to mess with running a cable from the generator to the cabin every time I'm ready for power - i want it to be ready when its fired up.
Preciate the help!
Fredonia Freeks ATV
-07 Brute-750 with a few...
http://community.webshots.com/user/AUCatRider
RE: wiring my cabin for a generator - 11/18/2008 2:35:45 PM
floridacrakr
first thing id say is figure out how big of generator youre gonna need. if you look around at home depot or lowes, they pretty much have everything you need. whatever you do, dont take a shortcut. its not worth it!
07 GRIZZLY 660
28" HL Outlaws
Custom Snorkel
HL Super Duty Clutch Kit
HMF Swamp Series
Radiator Relocated
http://www.myspace.com/ckeithb75
(in reply to AUgrizzrider)
RE: wiring my cabin for a generator - 11/18/2008 2:52:24 PM
kodiak660
Get a small breaker box that matches the output of the gen you pick out.
Put the lights on one 15 amp circuit, Kitchen outlets on a 20 amp circuit, the AC unit on its own single 20 amp circuit, and the water pump on its own circuit (15-20 amps depending on its draw)
20 amp circuits need #12 wire and 15 amp circuits need #14 wire
< Message edited by kodiak660 -- 11/18/2008 2:54:16 PM >
Video
07 Honda 420 Rancher ES 4x4
06 Outlander 800 XT 2,900 miles (sold)
03 Grizz 5,000 miles (sold)
01 Rancher 5,800 miles (sold)
00 Kodiak 7,500 miles (sold)
94 Warrior 6,500 miles (sold)
(in reply to floridacrakr)
RE: wiring my cabin for a generator - 11/18/2008 3:31:43 PM
camogrizz51
Yep run all your wires to a small panel.  Then just run a big wire you will probably need a number 6 depending on the generator, hook one end to the generator and the other end to the main on the small panel.  What i would do is wire a pig tail to the generator and wire a 50 amp plug onto the wire that goes to the main in the panel.  so it would be just plug and play if you ever wanted to have the generator serviced or used somewhere else.
2005 HD camo grizzly 686
2.5 warn
29.5" Outlaws on black type 7's
mudbuster cam
HL superduty extreme clutch kit
HL full skid plates
5.5" Gorrila Lift
Gorrila Chrome Moly Driveshaft
Relocated Radiator
HL Springs on all 4 shocks
start lockout mod
shift lockout mod
hmf utility exhaust, k&N pro-flow kit, and dynojet kit
Full Bayou snorkels
warn bumper and trail lights
more to come
http://community.webshots.com/user/pufferdude
(in reply to kodiak660)
RE: wiring my cabin for a generator - 11/20/2008 10:06:19 AM
AUgrizzrider
preciate the help guys!!
Fredonia Freeks ATV
(in reply to camogrizz51)
RE: wiring my cabin for a generator - 11/20/2008 10:40:32 AM
Swampthang
Not all generators are created equal. You can get by with lesser watt generator if you get a good quality one. I have a generac 4000 watt, and a Honda 3000 watt. The honda handles the load better even though it has a lower rating. The honda inverter generators are awesome. I love mine. You can put it 20 feet away, and barely hear it, and it is great on gas.
Sportsman 500 EFI
blown w/ nitrous oxide
12' snorkels
44" super swampers
20" lift
9.9 Mercury outboard
Lowrance depth finder
RE: wiring my cabin for a generator - 11/20/2008 1:11:42 PM
02Sleeper
Depending on how remote. I would put a breaker box on the cabin and run conduit under ground from the box to a stub out where the generator is. Where you stub out I would put a box and use a short pigtail to the generator.
On the stub out use a water proof box and put in a 220 stove outlet. (female) Then buy a 5' range cord and the 220 snap lock male plug for the generator. Be sure when you wire the box at the cabin be aware of the two phases. 110 on each leg. Then you can use al of the power and most generator have a 30 AMP breaker on them. If you try the 110 outlets they are 15 amp and will not hold up.
This way you can put the generator away when not in use.
This is how I have my house back fed for power outages. The only difference is you do not have permiante power. Clear as mud?
2008 Camo Rino 700, Snorkled, 28" Laws, SS 108's (current)
2008 RZR -
29.5 Laws, SS 212's Snorkle, Extreme lift, spacers, HL Lift springs, Warn 4.0 (Sold)
2006 Rhino 450
Extreme lift, EVO Big Gun, clutch kit, Snorkled
Big ole Stereo, leds etc...(Sold)
2007 Grizzly 700
29.5 Laws on SS112's
Snorkled, piped.
2005 Bombardier 400 XT
Custom "Wild Thing" paint scheme (sold)
2003 Kodiak 450
HMF Snorkle 28" Laws
2003 Arctic cat 300 4x4
Snorkled, EDLS, p
(in reply to Swampthang)
RE: wiring my cabin for a generator - 11/20/2008 1:21:05 PM
Swamp_Monster
You may want to think about driving a ground rod where the generator will sit and then another one where the service will enter the cabin.
Mud Racers!
Click here to check out www.XtremeMudRacing.com
A place for mud racers, by mud racers!
(in reply to 02Sleeper)
RE: wiring my cabin for a generator - 11/20/2008 2:02:30 PM
Scooped_Kawasaki
Home Depot or Lowes has just what you need for this. I think they call it an RV hookup or something like that. It has a hinged lid made to keep rain off the plug but it's far from waterproof. All the above suggestions are excellent.
1. Small breaker panel in the cabin.
2. Run conduit underground to a stub up by the generator.
3. Weatherproof box on stub.
4. Pigtail from the generator to the weatherproof box.
5. Ground rod at cabin and at stub. (most important in my opinion)
  • 04 Kawasaki 700
  • Radiator relocated
  • Hand crafted hood scoop
  • H/L 1" lift kit and springs
  • Stainless dry storage keg
  • 2"Spring spacers
  • Custom receiver hitch
  • 1.5" Spacers
  • 29.5 Laws
    If you find yourself in a fair fight, your tactics suck.
    (in reply to Swamp_Monster)
  • Post #: 9
